  New Posts New Posts RSS Feed - Speaker wring/ re-wiring
Safetyman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Safetyman Quote  Post ReplyReply Direct Link To This Post Topic: Speaker wring/ re-wiring
    Posted: 14 November 2017 at 4:19pm
So, my amps running @ 4 ohms are producing 800,1,200 & 1,600 watts per channel....
My speakers are rated @ 200/8r,400/8r,400/4r & 1,200/4r for the passives.
I, usually, wire/re-wire speakers with 1.5 mm tri-rated wire , whether they be bass bins or top/mids. This cable is rated @ 21 amps for 600V AC/1000v DC, despite it's diminutive cross-sectional area.
So, is this ok, or should I go for the 2.5mm tri rated version, at least for the bass bins( 1,200w ) please ?
Protect your hearing, and feel the music.
MU South East Roving Safety Rep.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Safetyman Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2017 at 8:26pm
Decided to go with the 1.5mm tri rated cable, as all my cabs are quite small  and the cable required would be no more than 1 metre in length for every single cable run.
Cheers
