  New Posts New Posts RSS Feed - Digi Pro Amp module Fixed!!!
byronit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote byronit Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2019 at 3:50am
Thanks for your assistance i have emailed the files as requested. The sub emits a hum possibly the caps are bad , ill  will check power supply for ac ripple, any other advise
fmatteo93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fmatteo93 Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2019 at 6:12pm
Good afternoon to everyone.
I also have some issues with my DIGIPRO 600M amplifier.
Can I receive the electrical schema?
Many thanks,
Matteo Falchi
ecoso View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecoso Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2020 at 7:04pm
Hi,
Are you still doing repairs to Digipro amps?
I have 2 for you to look at...
ed
AudioSystemsEngineer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AudioSystemsEngineer Quote  Post ReplyReply Direct Link To This Post Posted: 07 November 2021 at 3:44pm
Hi, who's successfully repaired Digipro modules ?
I've got a digipro1000 on the bench at the moment, SMPS is GOOD, Output FETs are GOOD.
Won't start with the O/P FETs in, No swithching waveforms on the FET gates on either channel.
I'm about to replace the IRS20957S drivers but seems a bit odd that i'm getting nothing on both channels, so its possible the shutdown is active.
LED 1 and 2 are lit, but their function is not labelled on the board or schematic.
any help apreciated :-)
mantasel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mantasel Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 10:47am
Hi, what could be wrong with Opera 712DX amplifier module? It is from dBtechnologies active speaker. RED LED blinks 7 times and pause, 7 times and thats all... No sound, nothing.. All Mosfets are good, checked, PSU and NTC protection voltages all are OK.. Could be software problem? 24LC256L memory is OK. How to full reset processor, PIC16F689? Could someone repaired it and could Help to me??
https://www.facebook.com/mantaspu/videos/5054032577968008
https://www.facebook.com/photo/?fbid=10220872881747993&set=pob.1118047132
https://www.facebook.com/photo/?fbid=10220872881787994&set=pob.1118047132
Gali būti tekstas „Balanced Input PUSH OPERA 712DX Limiter Signal Ready Link Sensitivity の 0๐ +4dB 0dB -3dB Flat Processed DIGITAL ACTIVE SPEAKER Line Mic COPo G2 Input-Link Input Sens dB dBç高“ vaizdas
voron View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote voron Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2023 at 2:53pm
Yes, I can fix your amp, even if pic16f689 is damaged. 7 blinks means that adau not loaded from eeprom or damaged
Post Options Post Options   Thanks (0) Thanks(0)   Quote mantasel Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2023 at 8:03pm
And what price for such fix to be about? Do i have to send only PCB board to You or anything else more? What country are You from? Thank for reply ;)
Post Options Post Options   Thanks (0) Thanks(0)   Quote voron Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2023 at 8:15pm
I'm from Russia, Tver. I think the shipping cost will be too much.
VECTORDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VECTORDJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2023 at 4:29am
It should be a Crime to sell Junk that is not Fixable.......CUSTOMER rip-off.....Over and over Customers are having Powered Speakers FAIL......Looking for Someone Who can really repair D-Class Amps in Maine USA......VECTORSONICS
Post Options Post Options   Thanks (0) Thanks(0)   Quote mantasel Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2023 at 7:14pm
Do You have processor and e2p dumps and can to share with me? Maybe schematic also? Thank!
Post Options Post Options   Thanks (0) Thanks(0)   Quote voron Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2023 at 7:29pm
Sorry, I have NDA restrictions.
This page was generated in 0.264 seconds.
