  New Posts New Posts RSS Feed - JBL 2226HPL Driver - Good in short horns?
Requiem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Requiem Quote  Post ReplyReply Direct Link To This Post Topic: JBL 2226HPL Driver - Good in short horns?
    Posted: 02 December 2017 at 12:02pm
Probably not a topic worthy of Advanced discussion but someone here is bound to know the answer,
Been offered a set of 6 JBL 2226HPL drivers for a pretty good price, they are 15" drivers with these specs:
  • 8 ohm
  • 600 W AES continuous pink noise power capacity
  • 4 inch (100 mm) edge-wound aluminum voice coil
  • 30 Hz – 2.5 kHz response
  • 97 dB sensitivity, 1 W, 1m (3.3 ft)
  • SFG magnet structure withVented Gap Cooling™ technology
  • Net weight: 8.7 kg (19.25 lb.)
    Im looking to replace the 15" drivers in my CSG tops, the xtro lookalikes with different 15" low mid section, similar to a HD ... (If you've been a regular on here for a few years you will know the ones). They've got mismatched drivers in currently and been looking to sort them out for quite a while now, havn't been used in years.
    Was wondering if anyone knows whether these JBL's would work well in the enclosure, I've never been too hot on matching up drivers to cabs I usually just use whatever the general consensus says works best. These are DIY cabs so no official specs for them...
    Any help appreciated
www.requiem-soundsystem.com
Custom Martin Audio WSX, USB & CSG Soundsystem based in Bristol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Requiem Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2017 at 1:02pm
Or if not, some suggestions on suitable drivers that wont break the bank would be good! I was thinking perhaps PD 154
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2017 at 1:05pm
is there a lot of room? some bandpass horns can be a bit tight on space.
i have 16 pd154s to get rid of so if you think further that way..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Requiem Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2017 at 3:00pm
Not a huge amount of room no, I dont have the exact box volume but its around the size of a HD... PD 154 was one I was thinking of, I shall drop you a pm LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Requiem Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2017 at 6:21pm
Ive just realised I've had this exact same discussion a few years back in another thread. so admin feel free to delete
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2017 at 12:30am
You do realize the mass corner is only 240hz?
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Requiem Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2017 at 12:36am
Basically, I taught myself everything I know through just doing it and finding out what works, reading on speakerplans and titbits of information fed to me by people that know more....
I run a soundsystem and can make it sound great but know absolutely NOTHING about cab building or matching drivers to cabs, hence why I posted asking for help.
So no I dont know that mass corner is only 240hz, & I dont even know what mass corner is. Please elaborate? This is why I posted, to ask people that know more than me Wink
Hemisphere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hemisphere Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2017 at 9:22am
He means the upper frequency response limit of the driver in a horn. (which is apparently [2*Fs/Qts])
Phase 1: Post on Speakerplans
Phase 2: ?????
Phase 3: Profit!
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2017 at 10:48am
IIRC, JBL 2226H have been known to shred/almost ignite in horns.
However, exceedingly good in suitable reflex cabs.
As previously stated, PD154 are very nice nice in many short horns/BPH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2017 at 11:20am
^ Correct, although the 2226 may work in a short horn,is not ideal. The much better E140 works a treat if you can find any thesedays.
PD154,or PD1550 also both good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Requiem Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2017 at 12:53pm
Cheers guys!
