All direct drive Turntable spindle motor need oil |
Post Reply | Page <12 |
kedwardsleisure
Technics SL1200/1210mk2 and others with the same motor should be oiled during routine maintenance as they use oilite (sintered bronze) bearings which dry out. If used dry they will eventually wear, causing the rocking platter symptom you sometimes find.
Any motor that uses a ball race won't require any oil there. |
North Staffordshire |
JAH
Registered User Joined: 08 November 2017 Location: LONDON Status: Offline Points: 95 |
So dont the SL1210 mark 2 have the brushless motor? The higher end DJ turntables now being built all seem to have brushless motors.
Edited by JAH - 12 December 2017 at 2:33am |
kedwardsleisure
doesn't matter whether the motor has brushes or not. It's the bearing-type that's important regarding lubrication.
Motors with brushes are rare in pro turntables, though quite common in midi-hifi style belt drive decks |
jbl_man
Correct. 35 Years ago when i was in the hifi trade,we used to sell the hi-end Technics SL models brand new, sl1400, sl1410, etc. Included in the box was allways a tiny bottle of oil to lubricate the centre bearing,one or two drops per year at the bottom of the shaft. |
JAH
How does one go about finding out the bearing type of a 16-pole, 3-phase, brushless motor ? This is the motor mainly being used on the higher end Dj decks especially the hanpins.
Edited by JAH - 12 December 2017 at 10:59pm |
kedwardsleisure
use your eyes
Xoc1
The big clue is the phrase 'direct drive' - This means that the platter is being driven directly - not with a belt or an idler wheel. So the platter is part of the motor and there is only the one bearing.
