  New Posts New Posts RSS Feed - 2x10" vented horn idea
 Post Reply Post Reply Page  <1 6789>
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2020 at 9:53am
Been looking at the design, really doesn't have much volume behind the drivers and wondering how much this effects its output.
What frequency will you cross it to subs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2020 at 12:52pm
Very good work. I ma working on similar 2x12 box.
However, this box does not really classify as a vented horn. Its a reflex box. :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2020 at 1:11pm
Ive been looking at drivers for a 2x12 version this morning!
BP1Fanatic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BP1Fanatic Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2020 at 6:50pm
These speakers came out nice as h3ll!
DJGeno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJGeno Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2020 at 2:45pm
Can anyone comment on how the horn flare interacts with the port? Surely it will have a negative effect on it with it being so close, and with the horn throat passing through it? Will this reduce the performance of the port? I'm a complete newbie and trying to understand the physics of it all.
Noud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Noud Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2020 at 8:43pm
Goodevening Guys,
I Started building some new subwoofers to replace my scoops.
so I looked at a lot of different kind of subs like:
-th18 xoc1
-cyclops
-tham18
-tham 15
-Cubo sub
-21 br
and finally a paraflex Altcon 15
I wanted to be smaller go just as low or lower en just as loud. (if possibleBig smile)
so I started reading and reading and a bit more of reading.
until I finally decided to go with the Paraflex Alton 15.
the Hornresp sim so a similar output and range as the scoop.
so I de build begon and there are some result in the pictures.
Keep in mind the scoop is about 590Liters and the Alton 15 only 312Liters
Green=scoop 18XB
Purple=Altcon 15ds115
HPF=34hz
LPF=100hz
Noud View Drop Down
edit
Edited by Noud - 02 July 2020 at 9:05pm
Tonskulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2020 at 10:32pm
Interesting! How about ground plane measurements? Measure at least 4meters away.
Noud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Noud Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2020 at 5:16am
I did it at 2m low volume and it’s about the same. ( don’t have a lot of space to test)
When there is a bigger space available I will measure it from some different distances Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 04 July 2020 at 12:00am
Measurements aside, how does it sound to you subjectively?
Interested in feed back on the paraflex vs horns, tapped horns and reflex.
Noud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Noud Quote  Post ReplyReply Direct Link To This Post Posted: 04 July 2020 at 9:44am
It sounds tide, clean, kick nice, makes the scoops sound "slow".
I havent got the change to compare them with anything als but scoops.
maybe in the future I will get the change. a friend of my got 18xb reflex.
For a good testing day I first need to find a space to test.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 28 August 2020 at 10:47am
Poor ancient scoops.. tapped horns and paraflex systems are todays stuff.
This page was generated in 7.484 seconds.
