Schematic / Manual Vestax PVC275 |
Post Reply | Page 123> |
Meat
Posted: 08 January 2018 at 9:12pm |
My DJ mixer died a death last year and a mate has offered me a partially working Vestax PCV-275 which sounds great but it needs a bit of love.
Anyone got any experience with these or a manual and schematic? I can find other models but that one dosen't seem to be available online. I thought that maybe this could be a nice unit to experiment with different opamps once I get it back to working. I'm also interested if anyone has any experience with doing mods like this as the DIYaudio guys seem to think that some of these are night and day improvements over the comsumer grade ones commonly found in mixers. Many thanks. |
dj jammin
Young Croc Joined: 10 April 2010 Location: southampton Status: Offline Points: 770 |
check the connectors! these vestax pcv are really low quality.. you see a lot with the input/output phono jacks having the outer ring or ground part ripped off by a phono cable.. would aim for something better.. probs not worth mending..
Reverence Sound system
Meat
Yeah, I did that to the PCV-170 I had in about 2001. I've got a whole load of spares from the dead mixer though so if it's that then that's the first neck-bolt for the frankenmixer lol.
Hz so good
Registered User Joined: 04 September 2017 Location: Unknown Status: Offline Points: 47 |
what's up with it exactly, I've got same mixer, got it off ebay spares or repair, mine had some rings missing from the phono jacks so I pulled em off the sub jacks worked fine, I then had trouble with the 6mm jacks one of my monitors would be quieter than the other, tried everything different cables even cables to decks, took it apart and there's a small board under the channel faders when I pressed it the sound would come back as if a connection was faulty, took it to a local place that repairs TVs and sky boxes, they had it apart couldn't find anything wrong with it an said it worked fine, so they didn't charge for anything, and it still works fine now, I looked all over the Internet for a schematic to see what was causing the problem, all I could download was the standard manual and a schematic for a pcv 170, which didn't help,
Meat
The problem is a high noise floor. High frequency artefacts which are especially noticeable on the monitor headphones.
I opened it up for visual inspection and noticed that the power supply caps had let the magic out. Replaced the 2 2200uF ones in the supply today and it still turns on (yay, I didn't kill it at least!). Sadly, the noise persists on the monitor. Haven't got around to checking if the noise on the 2 crossfader channels is still present also; just been running through the sub channel. I've a sneaking suspicion that I'm gonna have to just work through all the boards and recap the whole thing unless someone else has a bright idea. Maybe theres a standard place of where to look upstream of a powersupply that's had the caps go pop? On the plus side. Although many folk seem to diss whats inside a vestax all the original caps were quite nice Elnas. As always, any help greatly appreciated and if someone should happen to have the schematic then that'd be very handy indeed. |
Meat
Thanks to member sunpro I have the service manual now. Cheers for that
Meat
Got the little bugger on the scope today. Seems pretty nice. No problems at all.
Took it home. Ran just headphones, no problems. Plugged it into my ultradrive... ...HF noise present again. I went rooting and turned up my horns; it's present without the mixer. So in all, my ultradrive is putting HF noise out of the inputs and the outputs. I think this vestax story is wrapped up for now! Is this the famous 'frying eggs' ultradrive thing? Anyway, it's probably time to just start another topic. Thanks to all those who have helped or offered advice. |
odc04r
Sounds like it very much could be. Had it once before. Check all ribbon cables and board-board connector seatings for a start in the Berry. Good luck!
dbizaro
New Member Joined: 17 November 2020 Location: se uk Status: Offline Points: 2 |
HI do you still have this service manual or schematic
i have a mixer not powering and possibly has other issues - nights what i have been told Thanks anyone that can help Dan
Meat Substitute
Registered User Joined: 10 July 2020 Status: Offline Points: 79 |
Yes, I've still got all the docs I collected for the PCV-275. Can't get into my old account so I won't be able to send/recieve PMs until I've got 10 posts. If you put up your email I can send what I've got.
Meat Substitute
Also, the mixer is still running after all the tinkering 2 years ago. Wish I had more opportunity to use it myself but hey it was fun using it to mix at parties on in the beforetimes! Remember parties with lots of people and dancing? Them were the days.
dbizaro
HI
thanks that would be great once i have i will delete this message dan@itsaliveltd.com i do remember parties and working in clubs and festivals. stay safe thanks dan |
