new setup help required please |
Post Reply | Page <12 |
Hemisphere
Pretty sure he meant 'subs and tops', or 'bass and tops' - not to run the system in mono in case you lose something in the process, which you will - and possibly a lot unless you sum the signal, which is possible as Nickyburnell suggested.
As for the difference between bass and sub, technically sub bass shouldn't be called bass, because it literally means 'below bass'. People use sub and bass interchangeably for most low frequencies, but sometimes separate them where appropriate (ie if a system has separate speakers for subs and bass) Where you draw the line between bass and sub bass depends on context. I reckon 'bass' is properly anything down to 41Hz, that being the lowest fundamental generally used by physical instruments, but the line seems to hover around 45-60Hz depending on the scale of system and who you're asking.
Just to confuse things, 'sub' is also a colloqualism for 'the speaker producing the lowest range in the system' (because 'sub' on it's own just means 'below' - a speaker playing 70-120Hz is still the 'sub' to the main speakers in a small hifi system despite not playing any sub bass at all by any reasonable standard). To confuse things even further, the term 'sub' has been so widely abused that a new term 'infrabass' has come into use - I think it was an invention of the F1 marketing department. That just means sub bass, something their actual 'subs' aren't very good at producing. |
krazyneil
sorry for the confusion slip of the fingers ,I meant subs and tops from each channel of one amp if you buy subs with passive crossovers fitted you can then get away with using one amp for the system as you suggested I thought you wanted to build some subs hence the active crossover and two amps answer so if you bought subs with crossover fitted you would run from the amp into the subs and then link from the sub to the tops ,depending on the subs you use they may or may not have link out with a cutoff like 125hz, so they split the frequencies or might just be a full range output
Edited by krazyneil - 05 May 2018 at 1:09am |
GOD TOLD ME TO DO IT !!!!!
jammin75
hi there i have the kr8's the inputs run parallel or you could use a speakon splitter i take these out sumtimes very potent for their size i run them from 110hz and up i use a inuke 6000dsp i run 2 midtops on one channel and 2 subs from the other channel you can sum the inputs or run mono its your choice personally stereo for home or studio use |
djdavej
Registered User Joined: 06 February 2018 Location: MERSEYSIDE Status: Offline Points: 12 |
Again thanks for your inputs people, very kind of you.Ive been busy reading trying to educate myself about putting a decent sound system together suitable for doing weddings . That’s my target area, so the system needs to be suitable for them needs , catering from anything like 100-300 people.As stated I’ve got my decks and mixer and two Celestion KR 10 200w 8 ohm speakers which I love with a passion. My mixer is a Numark DXM06 and the outputs available are
Balanced left and right out Record left and right out Master left and right out What I would like to do is obtain another pair of KR 10s , run the top/miss on one amp giving 400 w left 400 w right. Then a separate amp and run 500w each side bass. Would this be a reasonable idea ? The two amp thing appeals to me so it’s not asking to much work load of a single amp, plus in the event two is better than one.Would I be able to do this with the outputs available from the mixer ? My only concern to this plan is the KR 10s only have one speakon input and binding posts red and black. So big question ??? How would I set them up 2 KR 10s left and right giving 800w output in total and what amp would I need ? 2000w 1000w each channel ? How would I run them together considering them only having one speakon input ? Series ? Parallel ? I have a dream lol- be nice if I could get this to work together.I really want to stay with the KR 10s and another pair may be available to me hence the plan Any advice as always wil be gratefully accepted
djdavej
Hi All
happy new year.Been busy working and saving towards buying more gear.its coming together now.Have purchased the following items in addition to the 2 KR10s i already own so now i have 4 KR 10s 200w rms 8 ohms to power these a Crown XLS 1502 -525 w per channel@ 4ohms using a speakon splitter. 2 Peavey UL 115 bass bins 500w rms each @4ohms-power these Crown XLS 2500 775w per channel l @4ohms. Just looking at cables to rig them all up,looking at sattellite 35mm poles to mount 2 KR10s onto the bassbins. 2 KR10s on tripods giving a little flexability to move them around. Gonna look at the best way to set up the amps for frequencys etc.So does this sound reasonable people ? I have a dream and its coming together slowly.Any advice please ?
mini-mad
I 've had a pair of the UL115 bass bins and found removing the internal crossover and loading them with fane 15xb drivers gave a deeper and warmer sound...
But to set up nicely you will require some sort of active crossover |
djdavej
Thanks for your input.The two amps ive bought both have the ability to set your crossover up youself at whatever frequencys you desire , both are class D amps. with built in crossovers and filters .Now i dont really understand the finer workings of these amps so im going to have to start doing some research and reading on how to set up and get the best sound from the new equipment ive now got. Im not sure yet if the Peavey UL 115s have got built in crossovers or not, and if so if i can set them up using my new amps.Open to advice here ppl, so thanks for any input in advance.
Edited by djdavej - 13 January 2019 at 6:08am |
