Odd scoop question |
tkroeker
Registered User Joined: 06 November 2015 Location: kansas Status: Offline Points: 101 |
Posted: 08 February 2018 at 7:51am |
Does anyone have pics or info on how you ran wire? i.e. from the back to the front and screw hardware to the side walls...lol
I know it should be self explanatory but rattle is what I'm concerned about and the logical way just seems so odd. Just got in 4 Dayton PA465's and Excited Thanks
Dub Specialist Sound
Seen/had/built nuff scoops over the years , thick ,thin baggy tight cable, never heard cable rattling tbh
seen ppl use cable clips to pin down cable, drill hole in rear baffle str8 to driver nothing realy to be conserned about
tkroeker
Hmmm, drill and straight through instead of zig zag up and down.
Awesome.
Yes bro, seen it loads of times,
then it tends to less baggy cable in the front chamber then tbh
tkroeker
you rock, Thanks.
odc04r
Drill the hole as close to the cable diameter as you can and seal around it well with silicone. Else pressure will find a way (out)
sn95
Registered User Joined: 10 March 2013 Location: USA Status: Offline Points: 351 |
I hate to be the bearer of bad news but the PA465 is not a good drive especially for a scoop.
tkroeker
we'll see lol. They are in the Garage. The math I did seemed pretty good.
Hemisphere
Depends what your aim is for the project, really. If you want scoops no matter what and that's your only driver option, go for it but don't expect optimal performance. It's a reflex driver not a horn driver.
tkroeker
Bet I got mixed up on what driver I picked... I started with the Omega Pro and the guy thats going to be running them wanted more Xmax and in looking through options.... I was thinking these listed themselves as scoop options but ,, nope. Oh well I will drop them in some reflex and sell them to him lol.
tkroeker
So what effect does having a high QES and QTS have.
These are QES - .62 QTS - .57 |
odc04r
Long and short of it, quite a weak motor. Small magnet, low magnetic flux in the gap, not many wire turns in the gap, small voicecoil. You get the idea.
