  New Posts New Posts RSS Feed - E100
E100
munkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote munkey Quote  Post ReplyReply Direct Link To This Post Topic: E100
    Posted: 12 March 2018 at 9:55am
Just purchased an e100 to run sub (punishers) and kick. 1st night out and once it was all warmed up, we started turning it up to see what it can do. It then hit the reds very quickly ( punished.) On doing so, all the lights then stayed on and wouldn't go off even when turned down. Turned it in and off and went back to normal. Then it did it again. It wasn't even getting the heat sinks on the punishers warm. This time we turned it up a bit more and it continued working fine. Didn't give the puns the hard running we were planning and the amp never stopped. Any thoughts please? We've used e45's and k8's on the punishers previously and I was underwhelmed by the SPL before it hit red on the e100. 3 puns a side btw
the midtops!
luton_soundman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2018 at 11:01am
have you checked the drivers? A faulty driver can make an amplifier clip very early. Just a thought
Post Options Post Options   Thanks (0) Thanks(0)   Quote munkey Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2018 at 11:22am
All drivers fine. Like I said, carried on running and we could keep pushing them up on the lms
the midtops!
SoundsUnlimited View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SoundsUnlimited Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2018 at 11:40am
This doesn't sound right, Our E-100s have quite a bit more headroom than an E-45, you sure its a E-100 not a lower model with the wrong front ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote munkey Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2018 at 12:21pm
100% e100. Baffled as to why the lights locked on but could continue to increase the power. Best send it to mc for a looking over I guess
the midtops!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2018 at 12:56pm
maybe a partial short somewhere that the E100 managed to blow clear
North Staffordshire
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2018 at 1:17pm
How many drivers on each channel? Could you have been hitting the overall current limit on the PSU? It's one of the downsides to 4ch amps, getting the power in.
As an experiment maybe try 1 or 2 channels running flat out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote munkey Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2018 at 3:04pm
It had been serviced before we bought it. We had 3 punishers a side on two channel's. But rh channels with the puns did it at the same time, both times. We've run 6 puns, off two channels of an e45, previously and you couldn't breath in front of the stack
the midtops!
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2018 at 3:17pm
Same venue? Same power supply?
Post Options Post Options   Thanks (0) Thanks(0)   Quote munkey Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2018 at 4:09pm
We've used the venue/room/ power supply previously. The punishers were not stacked in a block of six due to low ceiling, but as I said, we've used the room before.
the midtops!
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2018 at 5:21pm
Are you sure you don't have the Power Reduction Control switched on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote munkey Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2018 at 5:29pm
Nope. Tried putting it in different modes to see if we were being dumb/something wrong there
the midtops!
