How to parallel amps |
Post Reply | Page <1 6789> |
odc04r
But then you've got to be really careful not to cross the streams (of electrons). Which would be bad, very bad. |
Hemisphere
The flying speaker is patent pending and is my sole intellectual property. Carry on inferring it to be property of the community and I'll see you in court!
valve head777
Old Croc Joined: 27 July 2012 Location: East Sussex Status: Offline Points: 1781 |
Yeah, hadhad a reread and confused myself there. I understand what Earplug is suggesting now. Cheers.... |
Earplug
Also, I remember reading somewhere (Dave Rat?) that the bridging trick makes better/more efficient use of the amp´s PSU. I´ve never tried it myself, but does make sense.
Conanski
That trick only works on amps with dual power supplies, if there is only 1 supply then there are no gains. |
mk2_ginger_biscuit69
BEHOLD!! the lone surviving splittertron, carried around in my get out of jail free box for the past 15years. It aint pretty but it worked, and still does. Many a linkup and system has been run through this badboy, including shows like the mighty Vengaboys, the Wombats & Chico
mini-mad
She is beautiful!!!
Black n yalla tape holds the world together! |
fatfreddiescat
Yeah but that only 4 way bro. We need 5 way.
i do commissions. Though this is proper tried & tested pro equipment, used extensively in industry, and proven many times over. Doesn't come cheap! And wouldn't meet the approval of many people on here.
valve head777
You see, it's cheap skate solutions like that which have brought the world to the prephasis that we dangling over. I mean, how can the economy be kept strong if people don't go out and buy the most expensive solution they can't afford??
give me enough hazard tape and a soldering iron and i could probably fix the NHS too
APW
Nooooooooo you used hazard tape, It should have been gaffer tape... You bodge artist!!
