budget amp for pd1850 and pd154 |
Post Reply | Page 123> |
junoprobelaunch
Registered User Joined: 01 April 2018 Location: Devon Status: Offline Points: 298 |
Posted: 16 April 2018 at 2:29pm |
hi
looking into buying an amp/s to power 4 hogs loaded with PD1850s and 4 HD15's loaded with PD154's aswell as 2 mt102s. what are some reccomendations for budget amps that would run this setup?
Edited by junoprobelaunch - 13 May 2018 at 2:19pm |
APW
A bridged e-800 will deliver about 880watts, and you would
need 8 for the sub/bass section alone so that would be nearly £1100!!.... and it would still
be underpowered. The minimum load when bridged is 8R for this amp, so one driver per amp. An Inuke NU6000 will give 1100 watts RMS at 8R or 2200Watts RMS @ 4R per
channel so you could drive 2 cabs per channel.
The hogs and HD's would need separate amps channels as they require different processing. You would still need to power the MT102's, the power requirement would be dependent upon the drivers fitted. Edited by APW - 16 April 2018 at 4:43pm |
APW
The GX7 (the largest amp in the QSC GX range) is less than half the power of the Inuke and for what it (the GX7) costs you can almost purchase two Inukes. Another contender is possibly one of the Blue Aran Jam multi-channel amps…. Or even decent 2nd hand amps. Edited by APW - 16 April 2018 at 5:19pm |
jammin75
2 inuke 6000 to power the hogs properly 1 inuke 6000 to power all hd's and 1 inuke nu 6000 for the mt's
KB109
Registered User Joined: 20 February 2018 Location: England Status: Offline Points: 37 |
For £700 you can buy a jam systems q10. Still a budget amp but probably a little bit better than a INuke. 4channels at 2500watt a channel. Though blue Aran tested at 2200 per Channel. I’ve ran 8 pd loaded hogs off it all night long.
junoprobelaunch
how come you need 2 inukes to run them "properly"? surely you could use just one and have 2 per channel?
Hemisphere
You don't need two iNuke6000's to power 4 hogs, it's just a belt and braces solution for if you really want a no-compromises option to drive your speakers right up to breaking point.
There's nothing to be gained by taking that option unless you've already tried powering them with one (that'll put 1100w into each bin - plenty) and actually found that to be in any way lacking for your requirements.
Edited by Hemisphere - 16 April 2018 at 7:55pm |
APW
.... it depends what program material is being played. |
jammin75
i have been usin an inuke 6000dsp since 2014 been out a lot of times i know wot the amp is capable off it will power 2 1850 loaded scoops no worries have dun this myself it wont power 2 per channel properly no way not sayin it wont make sum decent spl but will run out of steam trust me |
nickyburnell
Quote
i have been usin an inuke 6000dsp since 2014 been out a lot of times i know wot the amp is capable off it will power 2 1850 loaded scoops no worries have dun this myself it wont power 2 per channel properly no way not sayin it wont make sum decent spl but will run out of steam trust me [/QUOTE] Been wondering about this. Have you used it on non Dubby (for want of better description) music at 4r? House, Techno, Rock, Pop? Reason for asking is because if two are definitely wanted that's nearly 700 quid which is used T5n or big QSC/Crown territory ta Edited by nickyburnell - 16 April 2018 at 8:08pm |
jammin75
safe nick i mostly use it at 4ohm a pair of subs one channel pair of midtops the other has dun a grand job over the years still does my wife (dj lady d ) plays all types of music it does a grand job i can hit the limiter wen playin certain types of music and we play it heavy a great amp light weight runs cool plenty of power
jacethebase
QSC 5050 is a fair bit of bang for the buck.
www.stage2sound.com |
