Dead drivers? |
Post Reply | Page 123 4> |
re-production
Registered User Joined: 16 February 2017 Location: Suffolk UK Status: Offline Points: 176 |
Posted: 21 April 2018 at 7:30pm |
Hello All,
Last night at our gig we running oberton 18xb1500 from an ab1590b bridged per driver we set limiters so that the amps were running just into Amber on full tilt. I left for 45 mins and came back and there was nothing from the obertons. They said the drivers slowly got quieter and quieter until the stopped working over 45 minutes. This happened to both drivers off both amps. Any thoughts on what happened? Thanks
njw
Have you tested the drivers since the gig?
re-production
yeah took the speakon from the tops and put it in the subs and no noise. The main question is if it could be the obertons not liking being pumped for 7 hours straight in a hot room
njw
Are the amps that were powering the Obertons still working ok?
re-production
Have not tested them by themselves but will give it a shot. Didn't have anything to test them with at the time
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2544 |
1300w of never ending heavy bass into a driver that is only rated 750w RMS. What you say? AES pink noise test signal has 6dB crest factor so 1500w AES = 750w RMS. A sine wave only has 3dB crest factor, did your processor limited bass even have that much? Edited by Conanski - 22 April 2018 at 1:23am |
re-production
The driver is rated at 1500w rms, 3000w AES
1300w of house music should be fine
Hemisphere
It's rated 1500w AES, 3000w program according to that link.
That said, I agree 1300w of house music should pose no problems. @Conanski, lol at the idea of 'music' with an RMS crest factor lower than a continuous maximum amplitude sinewave.
fatfreddiescat
If these were loaded in a small sealed chamber then you could easily halve their long term rated power. I once made the mistake of assuming no harm would come to a pair 600W 15XB's driven with a 300 Watt p/ch amp with hi/lo pass and clip limiters, came back toast - bloomin mashed ravers, were loaded in Martin 115 horn bins.
re-production
These are loaded in EAW BH882, fairly large chamber
Hemisphere
FFC: They really should have been fine. Were they being used as kick bins or subs? I would suspect undisclosed abuse/tampering especially if kicks.
re-production
They were being run as general bass, 34hz too 110hz. I am considering calling Oberton and seeing if they have anything to say.
