  New Posts New Posts RSS Feed - MOS FETS in passive crossovers
LeruSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeruSound Quote  Post ReplyReply Direct Link To This Post Topic: MOS FETS in passive crossovers
    Posted: 24 May 2018 at 8:01pm
It's the second time that I see a Passive crossover made on PCB with some MOSFets screwed on the heatsink. I also noticed there is a zener diode and a diode bridge. I assume this is iniorder to get an envelope out of power signal and probabily use fets as limiter. Is it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 8:33pm
what's the model of mosfet?
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeruSound Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 9:20pm
I saw an IRF540, but it's a common used one.. so N-ch enhancemren..
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2018 at 12:52pm
this sort of thing?
Edited by snowflake - 25 May 2018 at 12:53pm
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2018 at 2:57pm
I've seen that in a few boxes, usually "protecting" the tweeters- although by the time such boxes get to me the tweeters and MOSFETS are usually blown anyway - I don't understand why you wouldn't just use a lightbulb instead?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeruSound Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2018 at 3:45pm
Since I am not in commercial I wouldnt use light bulbs nor MOSFets limiters, but I understand why they do.. guess light bulbs is a less "aggressive" solution, but never conviced me at all.
Edited by LeruSound - 27 May 2018 at 6:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2018 at 10:53pm
a polyswitch in series with R1 could protect the MOSFETs and make that circuit very reliable.
