MT12" recomended drivers |
Dan12345
Registered User Joined: 21 February 2015 Location: spain Status: Offline Points: 30 |
Posted: 10 July 2018 at 3:31pm |
Hi all just have some MT12" made with out the 1" comp part and was wondering what would be the best drivers i have read all the forum pages but what im looking fore is some one that has used the Paudio SN 12"MB 600w Neo Driver as i understand that this replaced the sn 12"b 300w so dos it perform the same i personsly like the idia of it beeing doble the power as then thay wont get pused so hard Any info on this is welcom thank you in advance |
Keen
mate keep those new p-audio drivers away from mid-range horns, they've totally changed, they're all reflex drivers now.
a driver that suits your needs will typically have very low Qts factor, i.e > 0.22 take a look at the different parameters between the SN12MB and the older SN12B, they're actually quite different drivers; SN12MB - THIELE/SMALL PARAMETERS Resonance Frequency Fs 62 Hz DC. Resistance Re 5.2 Ω Coil Inductance Le 0.33 mH Mechanical Q Factor Qms 6.70 Electrical Q Factor Qes 0.44 Total Q Factor Qts 0.41 BL Product BL 17.00 Tm Effective Moving Mass Mms 63.36 g Equivalent Cas Air-Load Vas 43.64 Liters Effective Piston Area Sd 0.055 Sqm Half-Space Efficiency Eff 2.22 % Airgap Height Hag 8.0 mm Voice Coil Height Hvc 18.0 mm Voice Coil Overhang Xmax 5.0 mm VS Edited by Keen - 11 July 2018 at 4:42am |
boots-hifi
Old Croc Joined: 15 August 2011 Status: Offline Points: 2460 |
BMS 12n610 work well
Dan12345
Hi Keen thank you fore your input I hadn't really looked at the small parameters so thank you and here goes the next question I have been looking at the recommended drivers and maching the small parameters and the ones that seam more suited to the mt12 is B&C 12NDL76 but I also like the Fane Colossus 12MB and as I already run Fane in my sub and kik section was wondering wich would be better thanks again in advance for any info on this subject P's please do not recommend the Pd's as I don't like the clinical sound of pd
Edited by Dan12345 - 11 July 2018 at 10:22am |
https://www.speakerplans.com/index.php?id=faq10
clinical sound of pds? what have you listened to, to give you that impression? the mt12 horn was originally designed for the pd123ER |
bass*en*mass
12ndl76 should work, 12mi100 aswell, 12mb not really..
Dan12345
Hi cravings I just don't really like pd it's just personal opinion have never herd mt12 with pd but I do know that the mt12 was designed around P audio sn-12b or c 12mb but thanks for your input and ill keep it in mind you say pd 123er
Edited by Dan12345 - 11 July 2018 at 11:40am |
Keen
12ndl76
