Loud & powerful15" drivers for single bass reflex |
Post Reply | Page 123> |
djrobs
Registered User Joined: 19 July 2016 Status: Offline Points: 31 |
Posted: 11 July 2018 at 7:50pm |
Edited by djrobs - 11 July 2018 at 8:53pm |
Regards Rob
djeddie
What's your budget? And why 15"?
Dub Specialist Sound
Oberton
JonB67
JonB67
if loud is the key thing, why bass reflex?
nickyburnell
15tbx100
ceharden
Old B&C Sub15 design loaded with Beyma 15G400. Works for me....
djrobs
easy to build. What do you recommend of not BR?
Edited by djrobs - 12 July 2018 at 5:21am |
Regards Rob
djrobs
Regards Rob
djrobs
400€
Regards Rob
djrobs
400€
The size and easy to transport
Regards Rob
JonB67
If this question is why not recommend br, the answer is if you want max spl for its size then you'll get more out of a tapped horn than a br and that's what you said you wanted. Personally I'd build double 15 bass reflex for the flexibility, but that's for my needs not yours possibly. Also you then need more amp power and it'll double your budget for drivers. I have bms 15n630 in bass reflex and they go pretty loud. How loud is loud anyway? If you want to build bass reflex take a look at the p audio e15 600s. Good value if you're on a tight budget as you are. What amp do you have to run them? |
