21" Ported Horn design idea |
Post Reply | Page <1234> |
Ricci
Registered User Joined: 13 March 2017 Location: Louisville, KY Status: Offline Points: 69 |
Thanks for the kind words. I really enjoy the Skhorn sub and it was a long journey to get there and to this type of cabinet alignment using the newer types of long xmax, low Qts drivers. I eventually got frustrated with both FLH's and TH's size, folding and response limitations and found this type of design for the M.A.U.L. and Skhorn towards the end of 2014 as I recall. If I might offer some advice...Make sure you are doing your simulations with complex Le or Le simming engaged in HR. Either will be more accurate than not. Good luck with the cab design.
t.geessounds
Young Croc Joined: 10 May 2010 Location: US... New york Status: Offline Points: 908 |
anymore update on this project?
kevinmcdonough
hey as I said in the initial post, it was an idea that I was playing about with, but I'm realistically not gonna have the time to take it any further any time soon, hence putting the plans on here to allow someone else to run with it if they want. K
kevinmcdonough
A quick update on this plan for anyone that might be interested.
Was discussing it on another forum we bounced about a few ideas, and there was a suggestion that making it an offset horn would put less strain on the driver. Modeling it up and considering a few possible layouts it actually seems like it's a better design this way, easier to construct at the very least. While I've tuned it slightly higher and it doesn't drop down quite as low as the other design, just about touching 30Hz at -3db is more than enough for the work I do (live music mostly) and think it's better overall. Another discussion was about port area. Around 400cm2 as is in this design (two 6" pipes) is about as big as you can go before starting to think about having to fold things, but people suggested it was very small for a big capable 21" driver such as the 21DS115. I'd like to ideally see a bigger area too, but it doesn't seem all THAT small when you compare it to other commercially available designs. Many of Void's designs use a series of 3 or 4 smaller pipes that give about the same, if not slightly less, port area, and things like Martin Audio's various ported horn designs also use ports that around the same size give or take. BassBox Pro, the program I most often use for reflex speaker design work, seems to think it's ok, and thinks that at 1700Hz, it's RMS, it'll only be pushing air at around 21m/s in the ports. You need to push the power up to over 5000w before you begin to hit what it considers the danger limit of 34 m/s. I'd be interested on hearing people's thoughts on the port size, but I suppose it's something that can only really be answered for definite with a prototype and some testing, which I might try and do over the summer if I get a chance. I'm also not massively precious about the design. While I don't have any actual plans or cutsheets drawn up on paper, I'd be happy to zip up the solidworks file as it is for anyone who has access to that software, and they can get all the panel sizes and routing details and could have a go at a prototype if they wanted. (design is shown compared to the Othorn tapped horn in grey) Edited by kevinmcdonough - 25 April 2019 at 10:35pm |
VECTORDJ
A+
smitske96
I don't have any experience with ported horns, but how do you think one per side would behave?
ceharden
Very similar concept to one I built for some 15" drivers quite a few years ago now. Worked very well. I had a bit more expansion on the flare so the mouth was almost all of the front of the cab.
Oddly I never managed to get a similar design to look good in simulation using an 18".
luthier
Registered User Joined: 21 July 2013 Location: UK - London Status: Offline Points: 271 |
Out of interest, how was the excursion with the 15s around 50hz?
ceharden
Probably quite low because the port was tuned around 45Hz which would have controlled the excursion.
FOO
Very very interesting design!!
Im No designer, but this is a design i could be tempted to have a go at. But when you mention port size and air velocity being on the edge, i do get some concerns. But as you state, its getting a problem with 5kw of power. Thats alot of power!
if you are pushing the limits on port area then definitely use large flares at both ends to increase the max velocity you can use before it starts chuffing. if possible get the ports symetrical about the driver to minimise uneven loading. can't see in the pictures - have you used any throat adapter or is it just a circular hole the size of the diaphragm?
FOO
Just thinking loud.. What would happen if the round ports was replaced by a slot port? Would be very easy to make. But I must admit that round ports look sexy on this design :)
Edited by FOO - 25 October 2019 at 7:00pm |
