6-16 ohm amp to 4 ohm speakers cabinet? |
Shipibo303
New Member Joined: 14 September 2018 Status: Offline Points: 2 |
Posted: 14 September 2018 at 10:23am |
Hello guys, I'm a newbie and I don't understand the speaker impedance rules well. I wanted to ask you: My amp output impedance is 6-16 ohm and I want to feed it to speaker cabinet that consists of two 4-ohm mid speakers and one 8 ohm tweeter. Is it possible to do it without damaging the amp or speakers? And if it is, what is the best way to wire them? (The amp has 5 channels and 100W per channel) Thanks for your help!
Chris Grimshaw
Mids in series to one channel, tweeter on another. Make sure you've got a crossover in place, or the tweeter will not last long. Chris
Quality sound from Sheffield
www.grimshawaudio.com |
taurusty
Make and model of amp?
Conanski
Sounds like a home theater amp. If the 4ohm mids are wired in series and there is a passive crossover between those and the tweeter then the box has an 8ohm impedance overall and is safe to connect to your amp.. 1 box per channel.
