Faulty driver |
Explicit 2
Registered User Joined: 02 May 2016 Location: Staffordshire Status: Offline Points: 91 |
Posted: 15 October 2018 at 10:12pm |
Hi
I have a Wharfefale D 093 out of a LIX full range cab. Is no sound from the driver. What could be the fault? What's the best option repair or replacement Thanks
'Whether you believe you can or you can't your right' Im here to learn
nickyburnell
Can you push the cone in and out, if so put a meter across the terminals set on ohms? If no reading send it to RMJ Recones or Wembley Loudspeakers for repair or scour eBay for a similar driver. Get amplifier checked to make sure no DC current. If cone seized find a replacement driver
Explicit 2
Yes I can push cone backwards and and forwards
Thanks Nicky
