Proline 3000 - People blowing drivers or Amp |
Post Reply | Page <1234 9> |
rosssss224
Registered User Joined: 25 July 2012 Status: Offline Points: 447 |
People running scoops seem to come off okay but those of us with FLH seem to pop drivers...
levyte357-
From at least 10 years ago, someone here said, amp good for 2x15s per channel at 4 ohms, but not 2x 18s pet channel.
Jack_The_Ripper
Registered User Joined: 04 March 2018 Status: Offline Points: 214 |
So if it's widely known that as soon as you see a clip light the amp takes out your drivers why do people buy them? I had two but sold them and now power my dual 18 subs with two QSC RMX4050HD one sub per channel. I can't be sure which amp is best but has anyone ever tried the RMX4050HD alongside the Proline 3000 running subs in 4 ohms stereo?
I sold mine because although I never clip my pa system some of my mates do ease the level up a bit so I only used the Proline 3000 amps once at a party and wasn't prepared to keep using them if they definately would send the subs drivers into hell. Like I say I never tested the RMX4050HD alongside the Proline 3000 but I can say that although i'm underpowering my subs by about 200 watts per sub the RMX4050HD is definately capable of 40hz power continuously and my subs you can feel the sub bass in your stomach. I think if the amps are that dangerous to drivers then we need to put the word out to make sure no-one buys them and instead buys something with half decent clip protection.
Edited by Jack_The_Ripper - 30 October 2018 at 7:58pm |
nickyburnell
People who are with their rigs all the time is one thing. Dry hire or install one of those damn things and you will have issues.
valve head777
Old Croc Joined: 27 July 2012 Location: East Sussex Status: Offline Points: 1780 |
As mentioned before, put a limited infront, no issues. What's the problem? Why demonise an amp when user abuse causes problems? No amp likes to be clipped.
dj jammin
Young Croc Joined: 10 April 2010 Location: southampton Status: Online Points: 770 |
what valve said ^^^
Reverence Sound system
levyte357-
The problem is not really the amp. It's the people who incorrectly repeat the results of the German lab test. Lab test said 2kwpc at 4 ohms @ 80hz !!! That does not mean amp will do 2kwpc @ 4 ohms at 40 - 60hz, so people who think they can get that, clip the amp trying, and oh well.. Let us remember Crown MA3600VZ, will also eat drivers when out of steam, as that had no inbuilt clip circuitry!!!
nickyburnell
Because when they clip, just once, they cause a lot more damage than other amps in the same scenario. This is not hearsay or demonetization. I've owned one and the way it went from OK to nasty noise is not right. BPSound had one in install and it killed a load of Wembley B Lines and it was behind a Cloud Limiter. Post was about amps ability to kill drivers, if yours hasn't cool, fair play, the ones I was involved with were horrid. Maybe they are not all created equal?
Jack_The_Ripper
Nicky...
That's why I was asking why would anyone who's heard horror stories about the amp use one. If you only have to clip it once and it kills your drivers then surely something is wrong with the design of the amplifier or maybe it's internal components aren't what anyone would class as reasonable quality I don't know. I've seen my mates use cheaper amplifiers before like W-Audio, Samson etc...which have clipped occasionally and not destroyed drivers. Maybe the only way to really use the Proline 3000 is if you leave AT LEAST 3db headroom AND use a loudspeaker management system at the quality level of say XTA DP426 etc...which has excellent quality RMS and Peak limiters. And if they're not all created equal then it's obvious Deton Audio (who makes the Proline 3000 and Thoman rebadge as the Proline 3000) has VERY serious quality control and manufacturing consistency problems.
Edited by Jack_The_Ripper - 31 October 2018 at 10:32am |
rosssss224
At the end of the day DIY / hobbyists all want 4 x 18" subs ASAP and will choose to drive them with a cheap amp to have the big stack of bass quicker. Thats what we did and what others will do...could we have saved the extra £750 for a 'proper' amp yes. But we thought bugger it it will be fine most people seem to find i otkay and of course we'll careful not like those other muppets. Fast forward its 7am and everyones taken their eye off the ball and someone asks if the bass seems quiet.
The amp is designed to drive 4 x 15" medium powered drivers. IF you used an inf8 to drive boxes needing 1500w rms to get out of bed that would be labelled a 'driver killer' probably |
odc04r
Seen them used to drive pairs of X1s amongst others all night to some messy early morning situations. No issues.
Robbo
Quote from above "And if they're not all created equal then it's obvious Deton Audio (who makes the Proline 3000 and Thoman rebadge as the Proline 3000) has VERY serious quality control and manufacturing consistency problems." I bought a load of Deton Audio products from Jo at Ohm a few years ago and it was not a happy experience. All of the products were brand new boxed items and we had a 50% failure rate straight from the box--of the other 50% we only had one item still working OK after a couple of months so out of about 20 items to find only one OK says a lot about Deton quality and reliability. They were very crudely built, even the metal rack cases were bloody aweful and the internal components and pots were cheap tat. I would NEVER touch any Deton Audio product again!!!!!!!!! Edited by Robbo - 31 October 2018 at 2:44pm |
