  New Posts New Posts RSS Feed - Driver rating
Driver rating
Explicit 2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Explicit 2 Quote  Post ReplyReply Direct Link To This Post Topic: Driver rating
    Posted: 08 November 2018 at 8:56pm
I apologise if this has been covered before but I couldn't find it.
If a driver manufacturer quotes a continuous rate, a program rate and a peak rate, is the continous rate the same as the rms rate?
'Whether you believe you can or you can't your right' Im here to learn
Conanski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2018 at 9:00pm
Exactly the same.. no, but close enough for horse shoes and hand grenades.
Edited by Conanski - 08 November 2018 at 9:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Explicit 2 Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2018 at 11:08am
Thanks Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2018 at 5:00pm
In short, no. AES ratings are the norm now, and are measured using a standard which is freely available to read. It's essentially application of a shaped noise for a certain period. It is not the same as the RMS limit you need to use to prevent coils burning.
This page was generated in 3.562 seconds.
