21” Tapped horn |
Post Reply | Page <12 |
Author | |||
discosucks
Old Croc Joined: 06 November 2009 Status: Offline Points: 1548 |
Really nice!
BP1Fanatic
Registered User Joined: 02 August 2009 Location: Columbus, Ohio Status: Offline Points: 105 |
Love the all horn stack!
Jay michali
Registered User Joined: 10 January 2019 Status: Offline Points: 26 |
That Martin and Othorn stack! Please tell us what you think of this combo?
Cheif_Stringer_
Registered User Joined: 26 April 2016 Location: Northumberland Status: Offline Points: 119 |
/\ what he said
"nice one matee"
IvCu
Registered User Joined: 16 August 2014 Location: Netherlands Status: Offline Points: 26 |
Combo works great! I experiment a lot with eletronic/acoustical crossover points and results just keep getting more interesting. The only downside for many people is that combo like this is impossible to tune by ear - you really have to spend time measuring boxes and figure out how they work, especially together
I spent a long time modelling and drawing this design but never got round to building a prototype. It's 21" and 1220*850*610mm. Probably only does 35Hz but was designed to optimise max output per unit volume. Uses two sheets of wood plus another half sheet for bracing and double thickness mouth walls. I was going to mount the driver on a separate baffle to provide clearance and so that different throat arrangements could be tried. If anyone wants to experiment with a new design I can send the .dwg file |
kevinmcdonough
Are you set on a tapped horn?
I've been messing about with ideas for a 21" ported horn that is coming together nicely. It really seems to shine with the 21DS115 driver, but I can try and make a few adjustments see how your driver will go in it. I'm gonna pull up an old thread I started about it later today and get some people's thoughts. K
BP1Fanatic
Ported & tapped horns are both BP6's!
Ported horn = parallel tuned BP6. Tapped horn = series tuned BP6. |
Father-Francis
Yes boss Am still hooked on the tapped horn , i’ Had two B&C 152’s standing here for too long .
