Reversing drivers in BR. |
FOO
Young Croc Joined: 23 December 2018 Location: Denmark Status: Online Points: 813 |
Posted: 10 January 2019 at 10:48am |
Hi Guys.
Just a small question i cant find any Google answer to. What excactly does it do to reverse mount one driver in a dual BR box enclosure? I know it has something to do with elimination of 3th harmonic distortion. But what else? Any other pros and cons on doing this? We are talking a plain BR box with both drivers in the same chamber and on the same baffle.
MattStolton
Not that much!
In theory the movement of a cone away from basket, is ever so slightly different from its motion towards basket, as the air resistance of the basket will affect rearward motion. Also the basket can form (minor) disturbances to the rearward wave, forms of diffraction to the wavefront propagation. However, consider this resistance to motion of cone from basket, versus the resistance to motion from the cabinet, and port effects, and it all becomes a bit moot. In a double BR box, I doubt you could hear it, maybe just about measure it. In other styles of box, the effect can be more pronounced, and often will have an inverted driver, but this is often for ease of loading and physical space considerations, as much as lowering distortion numbers. Easy enough to try, and listen to try and hear a difference. Beware of emporer's new clothes syndrome when doing the listen, you may hear something because you want to hear it! One good thing, may be improved thermal dissipation, by exposing the magnet structure to the open environment, rather than the closed box, it should run cooler, minimising power compression effects. However, exposed cabling/connectors to pissed punters may be a detrimental effect, and the speaker terminals may offer a point to get an electric shock off, at high powers/big amplifiers. |
Pasi
Old Croc Joined: 25 April 2010 Location: Knutsford Status: Offline Points: 2733 |
Since we are busting myths and false info here from now on: So not. Not even remotely like that. First and foremost: It depends on drivers used. What push-pull does is reduce nonlinear distortion in the acoustical output of the said cabinet, excluding the port effects. Hence it depends on linearity of said drivers how much the effect ends up being. With lower quality (cheap) drivers the effect may be up to 50% reduction on both second and third harmonic distortion, it's not always like that. Biggest reason for nonlinear distortion is suspension stiffness asymmetry and second is inductance variation. 3rd thing is the actual BL, force factor, variation depending on which direction the cone is moving. This is caused by the plateset assembly and non symmetrical structure of it. As we can see on the pic below, there is a slight variation on Kms, the suspension stiffness and barely any change on BL. But Inductance varies quite a lot, which indicates that there is no shorting rings on this driver and thus doing a push-pull may have a slight benefit as it would make Inductance symmetrical. But on BL or Kms there is barely any benefit. So effect wouldn't be anywhere near 50% reduction. When using a driver with aluminium or copper shorting rings, they already stabilize the inductance variations and thus push-pull would make even less sense. But on cheap driver where you don't have shorting rings, got BL symmetry issues and your suspension isn't symmetrical either, benefits can be huge. And that's why you see / don't see it that much in the modern world as it's not always deemed necessary, unlike the olden days when drivers weren't as well engineered as they are nowadays. And effect is very audible on drivers which actually benefit from the push-pull. Drawback on push-pull is that spider flexing noise and cooling air noise can be severily audible from the driver with magnet pointing out. For example certain driver range from well known European manufacturer uses specific cooling method where air is compressed inside the plateset on a backward motion of the cone causing very loud bangs and noise even at low excursion rendering those drivers unuseable on push-pull design. Edit: On the left and middle graph on both rows, right side is coil out = cone forwards and left is coil in = cone backwards. Edited by Pasi - 10 January 2019 at 12:13pm |
godathunder
Old Croc Joined: 19 July 2004 Location: wicklow Status: Offline Points: 1833 |
and, of course, youll have changed the volume of the front and rear chambers
edit: whoops, misread it as bp, not br, so forget that there front chamber
Edited by godathunder - 10 January 2019 at 12:37pm |
LOUDER THAN LOUD
MattStolton
Busted! Principle is right though, cone motion towards basket is different to away from basket. Nice to see some measurements of non-linearity, didn't think motor and magnetic side of things would be such a significant source of the variance? |
Pasi
One would think, wouldn't he? |
MattStolton
So, for this driver, at -5mm X cone displacement, BL is 30, at +5mm X, BL 31.5.
5% ish? How "bad" was this particular driver, compared with others you have measured? Edited by MattStolton - 10 January 2019 at 1:05pm |
corell
Check out the voice coil magazine, plenty of klippel data on there.
Pasi
Well, as Qes calculation has BL squared as divider, your 5% just became 10%. 30x30=900, 31,5x31,5=992.5 It is pretty typical chinese driver. First one originates from Mediterranean area :) Edited by Pasi - 10 January 2019 at 1:20pm |
FOO
Well i think i got my answer 😁
Really Nice with such great answers. Thats going right into the wisdom vault 👌
