Porn Horns |
boots-hifi
Old Croc Joined: 15 August 2011 Status: Offline Points: 2463 |
Posted: 10 January 2019 at 4:29pm |
Who beat me to it and bought the porn horns from void via eBay?
spongebob
There's three left still under auction number 173731465527
boots-hifi
3s no good! I’m greedy and wanted all of them.
Djdarch
Old Croc Joined: 10 November 2005 Location: Newark, Notts Status: Offline Points: 1989 |
they've just sold, not me either!
MattStolton
What's Lev planning...
levyte357-
I need 1x more. |
levyte357-
Also what''s the recommended compression horn for these?
The one that was designed for it, I assume. You can rip it out of any Void Stasys Phil cabinet
boots-hifi
I’d imagine something like the BMS coaxial HF would work well. The original porn horns I think were loaded with P-Audio although Toasty or Brian M would be able to confirm this. Not to sure what I’d put in the 12” . BMS or B&C spring to mind, maybe Fatial Pro could fit the bill. I’d try and find the most suitable unit for the porn horn, sim it and then choose a HF based on these results. Either way I’d be interested to know what and if the newer drivers outperform the original pornhorns.
pfly
Old Croc Joined: 25 October 2007 Location: Helsinki, Fin Status: Offline Points: 2828 |
I think HF was Beyma CP-755Nd when Porn Horn was available Does anyone have directivity plot for the 12" horn? It would make it quite easy to choose appropriate HF horn to go with the thing
Yeah it was. Like I say, the Porn Horn v2 HF horn was repurposed to use in the Stasys Phil |
pfly
That I already knew. All things don't quite match though. I think Porn Horn was advertised around 40-60deg nominal while Phil is advertised as 80deg horizontal. If I was in a situation of looking for HF horn to go on top of Porn MF I'd most likely just measure the thing myself and then decide what kind of HF solution I'd like use with it based on MF dispersion, resonance and distortion characteristics.
Edited by pfly - 11 January 2019 at 12:43am |
