  New Posts New Posts RSS Feed - MTB-246 "Reborn"
MTB-246 "Reborn"
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2019 at 12:33pm
Originally posted by Mikkel Mikkel wrote:
Det var så lidt. Held og lykke med jers projekt :)
Hej Mikkel hvor befinder du, dig ?
Hej Father Francis. Jeg bor i Sheffield, England. Smuk by med dejlig mennesker. Hvorfor spørger du?
Det super måske kigger jeg forbi til summer , hvis du var her hjem vi kun måske få en kup kaffe eller brandvin🥃🍸🍻☕️
Edited by Father-Francis - 30 January 2019 at 12:36pm
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2019 at 1:00pm
Francis, i have been thinking about it, but will 21" singles be able to be used on theyre own, with a 15"+1,5" cab ontop for smaller gigs?
If i am going to build 21" singles, they will be made to replace some Dual 18 BR beyma 18g400 loaded, and some old DIY BR with a single beyma 18g550.
If im going the dual 18 BR-way, its only the old dual 18, that will get laid off 😄
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2019 at 1:33pm
Yes i don’t see why They won’t.the thing is br can go low and high at the same time if you’re doing a small party you could just run them from 35-150 which most of them can do , or to 140 if you are running like mt12
Mikkel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikkel Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2019 at 3:49pm
Jamen det må du meget gerne! Det er altid godt at snakke med et fellow speaker nørd :) . Jeg PM'er mit mail addresse til dig.
P.S. Sorry about the hijack FOO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2019 at 3:54pm
Tak jeg ved Foo har Ikke nogen problem med det ,
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2019 at 4:05pm
Mikkel, det gør ikke det mindste :)
Francis.. I will look into that a bit more then..
B&C and 18sound got some really nasty drivers!
I have also been looking at 18 inch mini scoops. but dont know how they will fit the bill. Havent heard scoops before :O
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2019 at 5:35pm
Mini scoops are not bad right scoop with The right driver , is killer , i prefer full scoops if am to use any , I got one some where will just look thru my laptop and pm you the drawing , maybe I have Mykeys animals series too on my pc , it hasn’t been on for three years now ,
