CF1840JD bassbin |
Author | ||||
Soundisreal
New Member Joined: 12 April 2019 Location: South africa Status: Offline Points: 5 |
Posted: 12 April 2019 at 10:04pm |
hi,
Can anyone please recommend a suitable bassbin plan for the celestion CF1840JD driver. I am currently using a dual pod bassbin enclosure from celestion website but not impressed. So I am open to single bins or dual. Reflex is best for these drivers. General purpose use for generally upsetting tummies!
Edited by Soundisreal - 12 April 2019 at 10:04pm |
Conanski
Reflex subs aren't rocket science, so what exactly have you built and how is is being powered and processed? Also how many of these do you have and what size events are you doing?
Conanski
Soundisreal
https://celestion.com/speakerworld/downloads/patech/134.pdf
That's the link to what I built. Running 8ohm 2 channel with a Hybrid 5000watt amp. Sound is ok. But missing punch.
gen0me
What is the simulation software used for stress testing here?
Soundisreal
No idea. But celestion thinks his model is great.
I use it for live jazz, disco, outdoor events. The sound is quite strange actually. It's as if the bass is only felt but not heard.
MarjanM
That looks like a car subwoofer box.
Conanski
How many of these boxes do you have?
Edited by Conanski - 13 April 2019 at 4:17pm |
Soundisreal
3/4 inch birchply outer , laminated to 1 inch cedar inner. Best of both worlds.
Drivers wired in parallel. One driver, one channel. Amp only supplies the bassbin. My behringer Ultradrive only gives the amp low frequencies. It has built in crossovers. I set it to 20 - 100 I have only one dual box I made and use. Seems to work better outdoor. Really gets the earth moving. But like I said before, it's just not audible enough.I am a mastercraftsman in the woodwork trade, so it's a quality piece with top grade hardware , connectors, finish, etc. Why do you ask, do you want one made? 8Ohm Setreo Power ,RMS/CH 1300watt. Drivers are rated at 1200. So right in the sweat spot there.
Conanski
