  New Posts New Posts RSS Feed - stupid question about tour labels
Mr Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mr Ed Quote  Post ReplyReply Direct Link To This Post Topic: stupid question about tour labels
    Posted: 31 August 2019 at 7:04pm
Ok   how do i wipe writting off a tour label so i can re-label it
been written on with a sharpie   tried  foam cleaner, label remover and good old white spirit   no luck at all
sure im about to be shamed with a simple answer here -)
thanks
John
It's Nice to be Nice !
Alex_C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex_C Quote  Post ReplyReply Direct Link To This Post Posted: 31 August 2019 at 7:10pm
Isopropyl alcohol Thumbs Up
Danny A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Danny A Quote  Post ReplyReply Direct Link To This Post Posted: 31 August 2019 at 7:45pm
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 31 August 2019 at 8:46pm
If IPA won;t shift it, then move on to Acetone. But be careful with it as it will likely damage the flight case surface and any other paint you get it on. Nail polish remover is acetone based.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mr Ed Quote  Post ReplyReply Direct Link To This Post Posted: 31 August 2019 at 9:04pm
thanks Guys  appreciate it Smile
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 31 August 2019 at 9:48pm
oven cleaner if you have that handy
kevinmcdonough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevinmcdonough Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2019 at 1:06pm
PAL cleaner as linked above is the official one, but a squirt of WD40 also works great Smile
James Tengo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Tengo Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2019 at 1:41pm
Drop of meths on a cloth also does the trick
AndyWave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyWave Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2019 at 2:51pm
Have you tried PRF label off, or other citrus based stuff?
Many times removes permanent sharpie markings off plastics, depending how long ink has been applied. Label off needs good few minutes to be effective.
Fresh citrus odour is a plus compared to tougher chemicals...
Next would be the oven cleaner.
Edited by AndyWave - 01 September 2019 at 2:59pm
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2019 at 11:24pm
As already mentioned, Isopropyl Alcohol (Isopropanol or IPA) is the best stuff to use.  Evaporates without leaving any residue, won't affect most other materials.  Also good for cleaning whiteboards etc in addition to removing flux residues from PCB's and many other uses.
Kr3 DSS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kr3 DSS Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2019 at 11:04pm
Scribbling over with a dry wipe marker and wiping it off, a few goes of that and its gone. Works a treat when the idiots use the wrong pen on the darts score board in the pub
Kr3
Destiny Sound System.uk
kr3dss@googlemail.com
Digbethdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Digbethdave Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2019 at 2:08pm
Ipa. Don't use sharpies. Get some pentel markers.
