  New Posts New Posts RSS Feed - Xta dp226 settings
Xta dp226 settings
Majestic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Majestic Quote  Post ReplyReply Direct Link To This Post Topic: Xta dp226 settings
    Posted: 15 September 2019 at 7:58pm
Is it possible to have stereo 2 way tops with mono kicks and subs? Manual and unit setup dont show that its possible. Thanks
Peter Jan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Jan Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2019 at 10:01pm
Long time ago that I had those in hand, but stereo 2-way plus two mono outs ( called Aux I believe ) is a possible standard configuration in DP226 and DP6i. Both Aux are fed  by summed A+B, which is just what you need for kick and sub.
Edited by Peter Jan - 15 September 2019 at 10:15pm
Phil B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil B Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2019 at 1:58am
Originally posted by Majestic Majestic wrote:
<span style=": rgb251, 251, 253;">Is it possible to have stereo 2 way tops with mono kicks and subs? Manual and unit setup dont show that its possible. Thanks</span>
Yep totally possible. I just programmed a DP6i with exactly as Peter J said using Audiocore.
2 x 2 way + 2 Auxes ( summed)
Ta
.p.
