  New Posts New Posts RSS Feed - Martin Audio H3
Martin Audio H3
Post Options Post Options   Thanks (0) Thanks(0)   Quote dylan-penguinmedia Quote  Post ReplyReply Direct Link To This Post Posted: 02 January 2020 at 3:36pm
Have a look for some W8’s if you’re going to go more than 1 a side on some WSX’s.
lorenzo31071997 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lorenzo31071997 Quote  Post ReplyReply Direct Link To This Post Posted: 02 January 2020 at 4:09pm
The W8 are not bad at all, but in Italy it is not found on second hand. I would prefer to build them, there is no mention of W8 anywhere on the web. As for the H3 / H3 + I already have how to configure the cuts, earnings etc.
Edited by lorenzo31071997 - 02 January 2020 at 4:17pm
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 02 January 2020 at 5:20pm
Originally posted by lorenzo31071997 lorenzo31071997 wrote:
I had never heard of Peter Morris, I did a search on the web and I did not find a personal site where to find the design plans. I searched the forum and found several products, but not something done and finished. How difficult do you think the production of these boxes would be? We read that the configuration is very difficult to make them sound good, even if the yield is statospheric (how is it possible with only 2x12 "to make 100-20K Hz?). There are many plans of RCF 4PRO, specific components to use and the configurations are ready
If you searched correctly you would have found tons of information.
Including which drivers can be used, and also their correct processing. Nowhere is said that it is very hard to get them sounding right. If you want the best of the cab it will become more difficult because you need the correct FIR processing.
PS: it doesn't only have two 12" drivers. The whole cab is mainly designed around the coax HF driver. You can use a 4" VC HF driver laike the RCF ND950 but you don't get the same result. If you go for the PM60 you can use two boxes aside (which would be loud).
Digbethdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Digbethdave Quote  Post ReplyReply Direct Link To This Post Posted: 02 January 2020 at 8:01pm
I guess your WSX are copies too?
Post Options Post Options   Thanks (0) Thanks(0)   Quote lorenzo31071997 Quote  Post ReplyReply Direct Link To This Post Posted: 02 January 2020 at 8:31pm
Yes, the WSX are also copies. There are many design plans for the WSX. I had the boxes made by a specialized company that made many of them, the speakers are RCF 18LP300 that fit perfectly
Edited by lorenzo31071997 - 02 January 2020 at 8:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 02 January 2020 at 8:47pm
If you're after some H3's, I have 4 here for sale. You can then open them up and copy to your heart's content.  Unhappy
Post Options Post Options   Thanks (0) Thanks(0)   Quote lorenzo31071997 Quote  Post ReplyReply Direct Link To This Post Posted: 02 January 2020 at 8:53pm
I'd pay for plans, but I'd like to build pits. Aren't you going to make plans?Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote dylan-penguinmedia Quote  Post ReplyReply Direct Link To This Post Posted: 02 January 2020 at 9:35pm
Not sure which part of “nobody here’s gonna give you commercial plans, it’s frowned upon and a bit shit” you’re not getting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 02 January 2020 at 11:31pm
here you go, this is a great start to reverse engineer. You need to get a 15" 10" & 1" driver in there, and make it weigh 77.5kg. Should be easy to do!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lorenzo31071997 Quote  Post ReplyReply Direct Link To This Post Posted: 03 January 2020 at 12:07am
I already had these data, did you want to make a joke?LOL
Danny A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Danny A Quote  Post ReplyReply Direct Link To This Post Posted: 03 January 2020 at 1:22am
deleted
Edited by Danny A - 03 January 2020 at 1:22am
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 03 January 2020 at 9:31am
Whilst it won't get you the H3, but here's a link to find the Peter Morris designs... either the 60 or 90 degree.
Also, why not have a search for the X-TRO?
