Crown 5002/5000vz replacement capacitors |
Post Reply | Page <12 |
kedwardsleisure
YOu will have to get exactly the same size because the VZ modules are held in place by the capacitor terminals, and the capacitors are clamped at the bottom by a pair of plastic clamps around their base. If they're too thin or thick the clamps wont fit and if they're to short they wont reach the clamp, which is mounted from the side. Without the clamps the main DC busbars are free to touch the metal lid etc which will not end well. There's only about 4mm clearance with the correct capacitors.
North Staffordshire |
APW
Good point….. It’s a very, very long time since I’ve worked on one of these!! |
snowphish
Registered User Joined: 23 February 2020 Status: Offline Points: 13 |
It doesn't look like there's any solution for a direct fit.
I will Macgyver / maybe 3D print something to keep everything in place with whatever replacements I find. the DC bus bar is also held in place by the output module anyway so it's not really that free to move
Edited by snowphish - 27 February 2020 at 6:10pm |
kedwardsleisure
oh it's free to move perfectly adequately if the clamps aren't tight.
service dept Steve
Sorry, I should have mentioned earlier that I may have a pair of used ones in stock, I’ll check tomorrow if I remember.
snowphish
Got a reply from Harman, unlike the Canadian distributor who I guess doesn't care to help out, they still have some for $70.98USD ea+shipping ... Let me know if you do and want to sell one and ship to Canada.
logsquared1
Registered User Joined: 09 February 2017 Location: USA Status: Offline Points: 115 |
Did you get your caps sorted out? I have a a set from an Amcron 5000 I am parting out. Need any other parts by chance?
