  New Posts New Posts RSS Feed - Users crest 10004 on sub (advice/findings) ?
Agayu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agayu Quote  Post ReplyReply Direct Link To This Post Topic: Users crest 10004 on sub (advice/findings) ?
    Posted: 12 February 2020 at 12:49pm
Greetings,
Anyone here using the crest 10004 on subs and got some good advice/findings about them ?
Bless
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2020 at 3:30pm
not really powerful enough by modern standards should you be looking to power anything big......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2020 at 6:30pm
Great amps , great bass....as long you dont want to drive zillion what drivers , go for it...
Pinyorouk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pinyorouk Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2020 at 8:22pm
Lookup Crest 8001 as the 10004 is 2*8001 in one enclosure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agayu Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 8:30am
We would like tot power 4 hog scoops with them loaded with pd1850's...
Is that to much because if i just look at the specs it should do the job :)
Thanks for the advice !
Edited by Agayu - 13 February 2020 at 9:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agayu Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 8:33am
Would be to power 4 x hogscoop (loaded with pd1850) :)
But since we dont have the budget to buy a powerfull new lightweight amp we wanted to start off with the 10004.. also heard a lot of good things about the 8001 for bass but was hoping to speak to some users to make shure we don't make a mistake buying one :)
Thanks !
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 9:40am
That's 750 Watts per driver, bit on the low side.
concept-10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote concept-10 Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 9:45am
The rated output would be a bit low but the 8001 is one of the best bass amps ever, are you going to be driving them to death? if not you will be presently surprised by how it sounds, 10004 is a gorgeous amp Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agayu Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 10:08am
Edited by Agayu - 13 February 2020 at 10:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agayu Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 10:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agayu Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 10:14am
If played @ 8ohm it would be on the low side yess but i think still enough for most venues we going to play.
But when played @4ohm bridged we got 1400 per driver or am i wrong ?
Still a beginner in al this so might be wrong :)
Thanks for clearing that up !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agayu Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 10:17am
Edited by Agayu - 13 February 2020 at 10:28am
