B&C 15SW115 |
UpComingSound
Registered User Joined: 21 June 2006 Location: United States Status: Offline Points: 393 |
Posted: 27 March 2020 at 6:47pm |
Do any one have any building plans for a single box for B&C 15SW115
smitske96
What are you looking for?
-Compact? (dimensions etc) -Extension? (>40 Hz?) -Max SPL? Normally you can pick two. Also keep in mind that the SW115 needs some proper power.
BASSHORSE
Young Croc Joined: 19 September 2007 Location: wolverhampton Status: Offline Points: 1160 |
mini scoop
UpComingSound
yes mini scoop or single reflex some ting compact give thanks
Noud
Registered User Joined: 17 August 2014 Location: holland Status: Offline Points: 66 |
This caught my attention last month. looks very good! hornresp record are available. Facebook group High Order Quarterwave Society (DIY Paraflex & Super Planar dev community)Direct link https://www.facebook.com/groups/bassaz/permalink/2782412598440516/
Edited by Noud - 28 March 2020 at 6:03pm |
smitske96
I saw your pm and respond on the topic (so more people can find some info).
If you want compact, miniscoop isn't the way to go. The BR option will be the compact option, miniscoop is bigger but gives you more SPL. You have to specify your max dimensions. If you are eventually going the BR way, I have a plan laying around. I am going to build it myself in about a month (with 15TBW100-8).
taurusty
Hey Smitske! Are U saying a 15DS115 is less efficient than a 15TBX/W 100? |
UpComingSound
i guess around 21 X 17 X 24
smitske96
Personally I would use the 15DS115 in a paraflex or something. 15TBW suits a BR perfectly and almost is much cheaper. @UpCominSound With those dimensions the only option really is BR, miniscoop will be much bigger. You do need a large port for such drivers, atm I have around 420 cm2.
UpComingSound
plans for a single reflex
djrobs
Registered User Joined: 19 July 2016 Status: Offline Points: 31 |
Edited by djrobs - 31 March 2022 at 7:23pm |
Regards Rob
djrobs
Hi do you have the plan for the br box?is it god ? can i have it ? i will build 2 boxes /Rob
Regards Rob
