  New Posts New Posts RSS Feed - Dual 12+ HF
Dual 12+ HF
 Post Reply Post Reply Page  <12345 7>
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2020 at 7:21am
@Teunos
Until now, I only sold the TH-18 cab which I've build Wink
And yes, this one would be for keeps. Or the results have to be bad LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2021 at 9:44pm
So the build has started with the modified cubo 21" and 15" 6th order BP.
Mid/high wil start in the coming weeks. At first one cab for testing and alterations, after that two final ones (4x10" + DCX464)
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2021 at 8:16pm
Also ordered Raptor Liner, curious about the outcome.
Bams View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bams Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2021 at 8:54pm
Thats some serious woodwork going on! But dont the 21” and 15” overlap?
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2021 at 9:57pm
Overlap as in frequency response? If yes, they aren't ment to be used together normally.
Obviously I will try it at some point in the following configuration: 21"/15" BP/ (12"/1") reflex top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2021 at 12:08pm
Ready for painting Smile
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2021 at 12:19pm
they look good. good work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2021 at 7:48pm
So far a good result with Raptor Liner:
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2021 at 9:03pm
the finish does look good indeed, congrats, i am curious about its meachanical and chemical long term durability - any experiences with aged Upolraptor cabs? :)
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2021 at 7:17am
Top work! You should be proud :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2021 at 4:58pm
All loaded, next are the grills and connector panels. When those arrive some extra spraypaint to make the insides a bit more black.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2021 at 5:21pm
very nice Stef! Top Job!
btw., did you use PU glue or regular white woodglue?
Edited by bass*en*mass - 21 January 2021 at 5:22pm
