help with designing kick |
Post Reply | Page <123 |
Danielr
Registered User Joined: 30 May 2016 Status: Offline Points: 209 |
i think that is probably worth highlighting... (and) I'd say even lower. Bottom of that article picks out 55hz for the batter head and 82Hz for the resonant head, you've rolled of 20db and 12db at those points respectively. (I guess it depends if you're are building "kick" bins to re-enforce kick, or building upper bass/lower mids to fill a gap in that you have.) |
keith192001
New Member Joined: 06 June 2020 Location: UK Status: Offline Points: 6 |
I want the enclosure tuned to 47hz or 50hz
totalAudio
Registered User Joined: 29 October 2015 Status: Offline Points: 27 |
yes I understand what you are saying, I should have specified it is really a low mid horn of sorts not a kick cab at all as I have this range covered.
With that in mind any thoughts? |
Jo bg
Young Croc Joined: 08 March 2017 Status: Online Points: 552 |
Hi again
First check your T/s parameters, re and qes seems off from those i found. Vtc you can measure volume inside cone with rice or similar method, and add that to vtc OR s2 in this kind of OD. if you use vtc you can use sd as atc, if using s2 for this leave vtc and atc at zero. Multiply for the number of drivers , 4 in this case. You can also double click on vtc box for a nice calculator. Edited by Jo bg - 06 June 2020 at 6:48pm |
