Lockdown Experiments |
Post Reply | Page 123 10> |
doober
Young Croc Joined: 03 January 2006 Location: Cornwall UK Status: Offline Points: 1118 |
Posted: 03 June 2020 at 10:16pm |
I've had plenty of spare time recently due to having no real work to do. Finally got around to trying a few ideas I've been thinking about for a while.
I had to use cheap nasty ply as it was all I could get, and will ultimately end up in a skip anyway. Drivers will be whatever I can find in the house or borrow from other boxes for now, I'm just testing the layout really. The box uses 2 10", 2 6", 2 1" Mid and HF horns are made from GRP. Unfortunately the local garage/ convenience shop only sells kits containing rather heavy mat, and doesn't have gelcoat, so they are a bit of mess... I made the moulds for the horns from silicone poured into wooden patterns for the mid, and a plaster cast from an MDF pattern for the HF. I later remade the mid horn moulds as they wouldn't flex enough, so I made some pre curved ones. |
Blahblahblah
dlyxover
Old Croc Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1502 |
awesome, be good to see it finished, loaded and some response plots
JulianDA
Registered User Joined: 29 May 2018 Location: Soest, Germany Status: Offline Points: 114 |
Thats some awesome DIY! And the idea to use silicone molds for the real curvy horns is nothing but genius. Thumbs up for that!
doober
I made some rear chambers for the 10" drivers, using a cut down plastic plant pot for a mould. GRP is the obvious choice, but as an experiment I also made one from a Stella box, a magazine, and lots of PVA. It is much stronger than I thought it would be, but took nearly a whole day to make. The GRP one took less than 2 hours, and I expect this to be less in future as my fibre glassing skills hopefully improve.
Blahblahblah
chris_k
Young Croc Joined: 14 April 2005 Location: United Kingdom Status: Offline Points: 1258 |
I remember when speakerplans was like this when i first joined. People posting build pics, experimenting.
Excellent stuff!
doober
I loaded the mid drivers, they came from some hifi speakers, I don't know the specs for them. The free air resonance was around 60Hz, a bit too low, so I sealed up the baskets with plastic and epoxy. This pushed the resonance up to around 500Hz. I have no idea where the mass roll off or inductance roll off will be.
I already have around 50 measurements, I won't put all of them up here! First is around 1m from the front of the cab, on axis, no EQ or filters. The low end is better than expected, I can't do much about the top end until I get the proper drivers. The dip around 1.5kHz is worrying- crossover to the comp drivers needs to be higher than that. Thinking the dip was caused by the open (both ends) hf horn between the 2 mid horns, I blocked the mouth of the hf horn with ply and plasticine. This is the result, an improvement. Next I unblocked the hf, and blocked both lf horns with cardboard and gaffer tape. The dip returned, as expected, plus a bit more loss around 1kHz. Below 800Hz has flattened though. Next obvious thing was to try blocking hf and lf, this gave me a new narrow dip above 1kHz. The big question is how this will all change when all the drivers are in. |
Blahblahblah
JonB67
Plasticine cardboard and gaffer tape?
You're a legend, this is awesome and I'm subscribing to this thread.
odc04r
That's great stuff! Loving the creativity. Hell of an experiment, and the weirdest "adult toys" I have ever seen. At least I assume that's what the pink silicone is all about really?
Noyzmunky
fantastic.
doober
I put the other drivers in today. It was a bit tricky getting the lower compression driver bolts in.
Hopefully next week I'll get some more measurements done. |
Blahblahblah
Digbethdave
Are the front baffles/guides asymmetric?
doober
Which bit? The ply horn mouth is 100 degrees, 50 left, 50 right. |
Blahblahblah
