  New Posts New Posts RSS Feed - Pioneer amp problems
Jimjimjimmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimjimjimmer Quote  Post ReplyReply Direct Link To This Post Topic: Pioneer amp problems
    Posted: 23 July 2020 at 9:22pm
Hi, just bought a secondhand pioneer gm d8604.. wired it to a liesure battery and a driver and nothing happening, no power light nothing... Anything I'm not thinking of before I send it back!?
Edited by Jimjimjimmer - 23 July 2020 at 9:22pm
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2020 at 1:35am
Check the manual, but usually on car amps where the power connects, there is a third terminal, will be labeled 'remote' or similar. linking this to the positive will power it up (if you haven't done this already) .
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2020 at 8:17am
+1  on remote, (acts like a relay, so power is permanent live and the remote cable comes from the head unit and tells the amp when the head unit is turned on.)
Car amps often have a built in blade fuse so worth checking the fuse if it has one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimjimjimmer Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2020 at 10:09am
Thankyou, thats it brilliant SmileSmileone further thing if anyone knows . It was sold on ebay as a gmd704 but the amp he sent was a gmd604. The specs are pretty similar from the look of things. Does any one know if theres much difference in them?
Post Options Post Options   Thanks (1) Thanks(1)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2020 at 7:45pm
Exactly 100.
I'll get my coat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimjimjimmer Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2020 at 8:18pm
Hahaha that actually took a minute!
