World's largest amplifier. |
jbl_man
Posted: 11 August 2020 at 12:07pm |
jbl_man
odc04r
All that fancy engineering with standard Neutrik I/O just makes it look a bit odd imo. Probably still cheaper than a top of the range Naim amp. O.
JBK
Registered User Joined: 03 March 2016 Location: Besançon Status: Offline Points: 262 |
All that for 12x 2000W @ 8 ohms? I fail to be impressed.Don't get me wrong if the specs are true it's a beast, but 600kg? 1.25 * 1.25 * 1m ? meh
jazomir
Will it drive my Auratones?
Conanski
It's definitely a work of art but it will look like total ass once all those 1.o braided cables are connected and spread out around the room on a forest of cable lifters.
Edited by Conanski - 11 August 2020 at 2:15pm |
jbl_man
How would you even plug it in....specs say 120amps @400v? That's one hell of a current draw!
GAZ.
Maybe they mean 415v 3 phase? And then 40 amps per phase?
100% Earth Moving Bass
csg
What you really want is a Wavac SH-833
Not as many watts but plenty of volts...
djeddie
But how does it sound with scoops? I'll get my coat.
M4trix
Where did he find all those matched transistors ? Directly from ON Mehico ? Darn, I had to buy 100pcs of MJ15022/MJ15023 in order to get 6 groups of 10 transistors ! They even had the same production date ( batch ) but didn't help much.
Edited by M4trix - 12 August 2020 at 9:14pm |
L8 ECU
Registered User Joined: 19 August 2015 Location: Wales UK Status: Offline Points: 77 |
The lady on the right.......do you think she practices safe sax ?
