  New Posts New Posts RSS Feed - Void V18-1000 vs B&C 18TBX100 in superscoop
heavydub View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote heavydub Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2020 at 5:53pm
Originally posted by knet94 knet94 wrote:
Hi, I'm the Ken referred to by Lev. Currently downsizing and have at least one selling. Looking £1,000 for well looked after specimens.
thank you Ken for the information!  As I told, I'm working hard on scoop bins now. In next months I'll find the best quality/price solution for the amp!
Originally posted by Sinai Sound Sinai Sound wrote:
Your HPF should never change, regardless of the amount of boxes you use
I'd set a super scoop to be 38hz 18db BW personally
Thank you very much. I will experiment around hints all of you are giving to me Smile
Originally posted by FOO FOO wrote:
You will be absolute pleased with a LAB FP14000.
Dont get blinded by what you read on here.
LAB FP and PLM amps are just as good and more, compared to Powersoft and Void.
They just cost alot more, so not many will spend the money on them.
But they are beasts.. No doubt about it. And more rider friendly Big smile
I could be wrong but from what I've seen, Powersoft X or K series are much expensive than Labgruppen FP. (if you consider specs-similar models of course).
I'll let you know my impressions with Labgruppen FP 140000 in next months.
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2020 at 7:18pm
If someone here is after the smaller Infinite 7v2, i have one hear for sale in NL Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote heavydub Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2021 at 1:24am
  • Add chamber wadding as suggested in Superscooper plans
Finally I started building superscoops. After few days of cutting and thinking I have a question: the superscoop plan says that you have to use 5cm of polyester fibre in the panel back to the driver. But doing this will result in the void driver that touch and "press" the fibre. Is this normal and safe or am I missing something?
MartinKanan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartinKanan Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2021 at 6:28pm
Is there anybody who have specs on v18-1000640 im curious to see if u can use it in a scoop the component is made for a 640 parafæex cabinet but some People say that it has better motor and better cooling ..
Please reply any information is gladly recieved
Kind regards
Martin Kanan
