  New Posts New Posts RSS Feed - Mini scoop driver choice
4bloc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4bloc Quote  Post ReplyReply Direct Link To This Post Topic: Mini scoop driver choice
    Posted: 25 October 2020 at 5:27pm
Hey all! Ive got 2 mk1 mini scoops from the 18”
Mini scooper plan on freespeakerplans (i believe its the mk1 staiper bins? ) Currently looking for the best modern driver options, looking for something high power handling. The sound will be used for dub/ bass oriented electronic music mostly and looking for something easily accessible in USA!
Edited by 4bloc - 25 October 2020 at 5:52pm
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2020 at 5:41pm
 Can you get hold of the Void V18-1000 where you are?
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2020 at 5:47pm
I have just aquired four Staiper MS-18 mk2. Would v18-1000 be a good match in them also? Or Maybe some more modern drivers would be more fun?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4bloc Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2020 at 5:51pm
Not super easily on the void stuff. Are any b&c, eminence, or beyma drivers up to the task potentially? Something in their high power ranges?
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2020 at 7:54am
if you have more than 248 mm space in the backchamber, i would try 18ds115  Tongue
will need a lot of juice though, but has low qts (0,2) and high linear excursion.
