  New Posts New Posts RSS Feed - Admark K30
Admark K30
 Post Reply Post Reply Page  <1 7891011>
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2022 at 7:52pm
hi, not sure if you'll find it useful, but i made a spreadsheet for the paraflex group on fb listing all the chinese amps out there - thought it would be handy for comparison.
never got round to finishing it but here it is anyway
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2022 at 11:37pm
Nice.
Made one as well a few years ago however, offered the rail voltage. More revealing when you add the dB differential in the equation. Would need to search my drives to locate if interested.
Best Regards,
WildKiller223 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WildKiller223 Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2022 at 10:41am
Hello Elliot!
I dont know if you posted it yet, or I just couldnt find it.
Anyway its been some time since you tested the K30, hows it holding up?
Any faults, problems yet? Im asking because im considering buying one
Thanks in advance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2022 at 11:50am
Originally posted by WildKiller223 WildKiller223 wrote:
Hello Elliot!
Thanks in advance!
Zero issues as it is approaching two years in service.
Here is the review:
Popularity seems to be minimum in Europe, in comparison to the United States and, the Caribbean.
Best Regards,
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2022 at 12:09pm
Hello Elliot!
Thanks in advance!
Here is the review:
Best Regards,
Just to confirm, are you using it on sub, low mid, or mids?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2022 at 12:29pm
Low Mids on JBLs as JBL offers a lot of "warmth" on their own. The EV (15's) don't offer a lot of warmth so they stay on the QSC (playing low mids as well).
Best Regards,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2022 at 12:57pm
I forgot to add...
Low Mids: 500 Hz (-3dB) to 35 Hz (-3dB)
Despite I use the K30 for Low Mids, the amplifier is being fed bass frequencies well within the range of many who tune their subs to (for example 100 Hz - 35 Hz).
Best Regards,
taurusty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote taurusty Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2022 at 3:22pm
Y so low Elliott?
Wont that give rise to phase anomalies when sub amp is turned on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2022 at 2:19am
Originally posted by taurusty taurusty wrote:
Y so low Elliott?
When you use reflex boxes that are tuned nearly the same, such issues are not a problem. Of course, from a chart standpoint, the phase response are not identical amongst the two. However, if your ears cannot detect it, you are merely chasing something based on a visual perspective and, not letting your ears be the deciding factor.
Best Regards,
Edited by Elliot Thompson - 17 November 2022 at 2:21am
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2022 at 10:13pm
Anyone have an update on the AD430?
T Willy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T Willy Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2022 at 11:15pm
A buddy here got one back in July. It is quite stout! He's using it to drive kicks and tops. So far no issues at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2022 at 11:23pm
Not expecting it to do four channels of 4 Ohm sub. But curious if it can do two channel 4 Ohm (nominal) sub and two channel top.
