Admark K30 |
Post Reply | Page <1 7891011> |
teeth
hi, not sure if you'll find it useful, but i made a spreadsheet for the paraflex group on fb listing all the chinese amps out there - thought it would be handy for comparison. never got round to finishing it but here it is anyway |
Nice.
Made one as well a few years ago however, offered the rail voltage. More revealing when you add the dB differential in the equation. Would need to search my drives to locate if interested. Best Regards,
WildKiller223
Registered User Joined: 22 October 2022 Status: Offline Points: 14 |
Hello Elliot!
I dont know if you posted it yet, or I just couldnt find it. Anyway its been some time since you tested the K30, hows it holding up? Any faults, problems yet? Im asking because im considering buying one Thanks in advance!
Zero issues as it is approaching two years in service. Here is the review: Popularity seems to be minimum in Europe, in comparison to the United States and, the Caribbean. Best Regards,
levyte357-
Just to confirm, are you using it on sub, low mid, or mids?
Low Mids on JBLs as JBL offers a lot of "warmth" on their own. The EV (15's) don't offer a lot of warmth so they stay on the QSC (playing low mids as well). Best Regards,
I forgot to add...
Low Mids: 500 Hz (-3dB) to 35 Hz (-3dB) Despite I use the K30 for Low Mids, the amplifier is being fed bass frequencies well within the range of many who tune their subs to (for example 100 Hz - 35 Hz). Best Regards,
taurusty
Y so low Elliott?
Wont that give rise to phase anomalies when sub amp is turned on?
When you use reflex boxes that are tuned nearly the same, such issues are not a problem. Of course, from a chart standpoint, the phase response are not identical amongst the two. However, if your ears cannot detect it, you are merely chasing something based on a visual perspective and, not letting your ears be the deciding factor. Best Regards, Edited by Elliot Thompson - 17 November 2022 at 2:21am |
smitske96
Anyone have an update on the AD430?
T Willy
Registered User Joined: 07 February 2022 Location: Wisconsin Status: Offline Points: 43 |
A buddy here got one back in July. It is quite stout! He's using it to drive kicks and tops. So far no issues at all.
smitske96
Not expecting it to do four channels of 4 Ohm sub. But curious if it can do two channel 4 Ohm (nominal) sub and two channel top.
