  New Posts New Posts RSS Feed - Admark K30
Admark K30
 Post Reply Post Reply Page  <1 891011>
taurusty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote taurusty Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2022 at 11:43pm
U lucky! There's  one culprit here using a 430 for 2 ohm bass on all 4 channels!
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 16 December 2022 at 3:23pm
AD42 buyers,
What is recommended site to buy from ?
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 16 December 2022 at 4:02pm
AD42 buyers,
You can contact and buy from them directly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2022 at 7:24pm
So I ordered two AD430 DSP's, will report back about my findings (eventually LOL).
vibes92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vibes92 Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2023 at 9:31am
ad42 or the powersoft x8  (if money was not an issue?)
Post Options Post Options   Thanks (0) Thanks(0)   Quote taurusty Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2023 at 1:10pm
X8.
AD 42 does not have DSP, 6 extra channels and until I see a reputable  review, honest power. A number of them have power supply issues here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2023 at 1:50pm
Originally posted by taurusty taurusty wrote:
X8.
If  money was not an issue, many say the X4L, is the daddy sub amplifier right now.
Many have stated, X8, is not optimal for sub on all channels.
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2023 at 3:26pm
No at 2 ohms per channel maybe, at 8ohms per channel it certainly doesn’t have an issue, and at 4 you will be running out of power supply puff if really pushing it
Im still to meet a sub driver that can’t be destroyed in rapid time with a x4 or x8 channel, the X4L is a monster and if you want to run lots of cabs per channel down long cables it can make sense, but personally I’d rather have the flexibility of those other 4 channels
After all 8 channels is quite a few, a sound near me runs 2 X8’s, but the whole system( 4 scoops, 4 18”kicks, 2 2x12 mids, 2 2” horns and 2 4 way bullet boxes) runs at full chat on 5 channels of just one of the amps quite happily. It is normally configured across 7 channels with 2 sub and 2 bass.
The second amp is for future expansion or as a spare. Its quite formidable now, 8 scoops on both amps is going to be scary…
Edited by csg - 11 January 2023 at 3:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2023 at 5:53pm
X4 and X8 @1600W/8ohm is not nearly enough for any high power 18. They are not enough for some of higher powered tops out there. I never understood why powersoft killed the K series without a proper replacement.
Yeah there is the X4L but i can buy a new car for that money. And yeah, a customer of mine had 4 of those blow up their PSUs running our subs last summer. So... go be a smart one and figure out where to put your money these days.
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2023 at 8:03pm
It’s more than enough for any of mine thank-you, more than enough.
My largest subs RMS limit at 80V, peak at 170. Standard X4/8 channel does that with ease.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vibes92 Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2023 at 11:11am
see iv hurd a few sounds using x8 and admark and they both sound good, i did prefer the x8 though in my opinion
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2023 at 3:46pm
@vibes92
Which Admark was used, and could you explain the difference between the two?
I have a pair of the AD430 and am just curious.
