Best Way to Paint a Soundsystem? |
Sam_Avantí
Registered User Joined: 04 November 2020 Location: Bristol Status: Offline Points: 21 |
Posted: 08 January 2021 at 11:39am |
Easy gang,
Soon I will be painting 6 x custom WSX and 3 x custom F215 MKIII's. Also got 4 x W8C I want to paint. The WSX and F215's are 18mm ply. W8C is original. I am going to keep the WSX and F215's the original ply wood look on the outside, what will the best way be to protect the wood, varnish/lacquer? And then I want to paint the accentuations, what is the best paint for this application? Cheers Sam
Stay Toasty
Sam_Avantí
Also, best method of painting? Spray? Brush?
Stay Toasty
Bams
Problem with laquer is the fact it scratches so easy but also looks best... i stained the wood and after that applied some wax mixed with ash to give it a bit worn look. Scratches arent really notable that way but its a bit of a cheap trick :)
Danielr
Registered User Joined: 30 May 2016 Status: Offline Points: 209 |
Depends what you want to do, - if you're planning on installing them somewhere where they'll never move, vs wanting a a finish that stands up to being loaded into/out of vans throughout their life.
Sam_Avantí
Will be touring, in and out of vans a lot... so needs to be hard wearing
Stay Toasty
MarjanM
Then make covers for the speakers.
Sam_Avantí
What do you mean?
Stay Toasty
DMorison
etc
Requiem
Old Croc Joined: 20 January 2011 Location: Bristol Status: Offline Points: 1805 |
If its touring, its hard work to maintain them with wood finish, but it can be done, re: Elektrikal and Elusive sound system's, speak to them and get the pro's and cons, both similar to what your talking about specifically Elusive, Ive heard Ryan talk about the horror stories of trying to maintain his wood finish throughout touring the system though, he uses clear tuff cab as far as I know but best to speak to them, not sure what Elektrical use but their system always seems well maintained and tours a lot.
www.requiem-soundsystem.com
Custom Martin Audio WSX, USB & CSG Soundsystem based in Bristol |
Requiem
As for just painting them, it depends on budget and how much hassle you want really, the most durable stuff as far as i know is stuff like truck bed liner like Raptor paint which ive heard good things about but not used myself, you can get them LineX'd but I don't think that's something you can do yourself and its expensive,
For ease of application , personally I just use Tuffcab and have a handy tin to touch it up when needed, water based , although i know its not the best, Warnex is supposed to be better afaik Aiming to get Raptor painted myself but no funds atm If your only using the paint on accentuations (such as bracing) its not going to see a lot of wear so personally id just tuffcab and touch it up when necessary Edited by Requiem - 12 January 2021 at 2:19pm |
I-shen Soundboy
...and let us not forget to mention the poor man's pro choice Warnex.
Anout four times the price of tuff-cab, but lasts longer without touch ups and is very safe to apply. Looks good with a roller. Looks fantastic with a spray gun. |
APW
About 6 years ago I was given 5ltsr of Coo-Var water based black Acrylic floor paint and I painted my subs with it, its cheaper than Warnex… at about the same time I repainted my tops with Warnex, the Coo-Var needs longer to fully harden than Warnex but once fully hardened the Coo-Var seems to mark less than the Warnex and is easier to touch up when it does get marked. When dry the Coo-var paint and Warnex look almost identical. The Coo-Var paint is also available as a 2-pac product.... the 2-pac is avaliable in clear. the paint in the image above is the water based Coo-Var floor paint was applied with a roller about 6 years ago. https://www.coo-var.co.uk/products/floor-sport-and-line-marking/acrylic-floor-paint Edited by APW - 12 January 2021 at 3:54pm |
