Super Scooper front baffle - double up? |
insguy
New Member Joined: 16 September 2019 Status: Offline Points: 7 |
Posted: 11 February 2021 at 10:31pm |
Hello and greetings!
First of all sorry if this has been asked here before, I was not able to find the information here (or anywhere else) so here we go: I am planning to build the "original" Mogale 18" Super Scooper. I heard or read somewhere that it is advised to double up the front baffle to give it more sturdiness. Please correct me if I am wrong. I have a simple question: If I double up the baffle, do I "stick it onto the front plate" (resulting in the driver reaching not as far into the cabin) or do I put the 2nd sheet inside of the baffle (hereby reducing the front chamber size). I hope I was able to make myself clear and am looking forward to replies. Thanks!
fat_brstd
Old Croc Joined: 23 August 2008 Location: Melbourne, OZ Status: Offline Points: 2125 |
Double Baffles are definitely a good idea on scoops. Either way to do it that you mentioned will be fine, if you wanted to you could adjust the panel back 9mm so that the extra baffle sticks out 9mm more than normal.
If it was me I would just put the extra panel on the inside as its easiest to work out and will look nicer when the build is finished than putting it on the outside. Remember that 10mm really doesn't make any difference to sub frequencies |
Melbournes Rootical Warrior Roots - Dub - Steppers facebook page |
levyte357-
No need for 36mm driver baffle, 25mm will do it.
Tried it, compared it. Lot of people use 36mm driver baffle, but fail to adequately brace rest of cab. Also SS18 chamber is real tight compared to other Scoops, would not reduce it, even further. |
insguy
thanks for your answers!
levyte357-
Would also say, as said before, the free 18" plan, Mykey gave away here, will excel with many more drivers, and has version with double baffle. Edited by levyte357- - 17 February 2021 at 3:47pm |
king david
I know people who put a double baffle on superscoopers to accomodate deeper drivers. To my knowledge it is working Ok with no failures
levyte357-
Obviously only worthwhile if cab deepened. But Mykey plan has this already. Edited by levyte357- - 18 February 2021 at 8:51am |
heavydub
Registered User Joined: 07 October 2020 Status: Offline Points: 23 |
I was about to finish my first superscoop build when I saw this topic. Do you think doubling up the front baffle is absolutely necessary? I'm going to load scoops with V18-1000 drivers.
I have a couple of questions: Lev said it's better to avoid reducing the chamber size of superscoop. This means that if you want a double baffle, you need to put the extra panel outside (resulting in the driver reaching not as far into the cabin, as insguy stated). Could this thing ruin any sound performance considering Im building standard super scooper, v18 loaded with (potentially) 10mm extra baffle panel? Also, mr lev said that 25mm is enougth. I have a single front baffle 18mm deep now, with birch ply wood. Should I buy again birch (10mm deep) or maybe I could use another kind of wood for the (potential) second baffle panel?
fat_brstd
If you can do it then it does benefit the sound but if you cant do it then don't worry about it, the box will still sound good. The main thing, which is much more important that a double baffle, is to make sure that you properly brace the internal panels to prevent resonances all the way along the horn. |
