  New Posts New Posts RSS Feed - WATTCO SCOOPS
WATTCO SCOOPS
KidCreole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Topic: WATTCO SCOOPS
    Posted: 28 February 2021 at 11:21pm
Mykey Wattco
Pinyorouk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pinyorouk Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2021 at 3:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2021 at 9:43am
1850 as standard choice
but with a 36mm front baffle you can use the leathel NLW9601Wink
Mykey Wattco
jammin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2021 at 10:41am
Thumbs Up
luton_soundman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2021 at 11:47am
Id go 1850! Never dissapointed everytime ive heard them in wattcos
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pinyorouk Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2021 at 3:15pm
Thank you
APSUS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APSUS Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2021 at 5:26pm
Is the bolt pattern the same from the 18NLW9601 and PD1850
Edited by APSUS - 08 March 2021 at 5:28pm
Western Mystics View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Western Mystics Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2021 at 8:33pm
don't have a facebook is there another way to get in touch
Edited by Western Mystics - 27 March 2021 at 1:07pm
djkeet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djkeet Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2021 at 3:48am
@ APSUS_ the cut out is slightly bigger plus the driver deeper
Edited by djkeet - 12 May 2021 at 3:52am
Soundbite
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2021 at 1:07pm
Hey Mykey,
Would PD186 work reasonably well in the wattco?  Asking for someone that is stuck with those drivers, and would like to find the optimal scoop to hit below 40hz with a block of 4 pd186 loaded.
How would the wattco compare to standard 18" supers, both pd186 loaded?
Cheers, Bob
Edited by bob4 - 30 June 2021 at 7:53pm
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2021 at 4:03pm
Originally posted by bob4 bob4 wrote:
Hey Mykey,
Cheers, Bob
PD186 in these would be waste of great Scoop, and drivers won't last long, if looking for 40hz with authority.
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2021 at 12:34pm
Thanks for the heads up Lev! The guy with the 186s proceeded to build a pair of Gsubs, and is happy with the result.
This page was generated in 0.110 seconds.
