  New Posts New Posts RSS Feed - Best driver for single 15” reflex bin?
Ajsski99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ajsski99 Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2021 at 3:12am
Originally posted by ceharden ceharden wrote:
You need to narrow down the search a bit please.  A few questions that might help you and other users:
* What is the volume and current tuning of the cabinets (or at least post the dimensions of the box and the ports)
* Do you have any preferred manufacturers or ones which you can get better deals on?
* Be more specific about your budget, give a target price
* What kind of music are you most likely to be using them for and in what kind of venue
* What other speakers are they likely to be used with (what are your mid-tops etc)?
I have managed to get the cab measurements:
H: 25” or 635mm
W: 18” or 457mm
D: 22 1/2” or 572mm
Small ports two on each are 4” or 102mm each.
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 8:49pm
At a rough guess without knowing all the internals you're looking at about 100L which is a pretty sensible volume for most 15" reflex-suitable drivers so I'd stick with my previous recommendations.
You might need to re-tune but 4" ports should be easy to adjust with new bits of pipe etc.
