Is this a good Acoustical Chart for 18 Tapped Horn |
Apex Predator
Registered User Joined: 11 July 2013 Status: Offline Points: 46 |
Posted: 04 July 2021 at 7:35am |
Is this a good chart for a 18'' tapped horn. Using an RCF G400. I'm now learning about Hornresp and trying to understand the graphs. Thanks for the help in advance
Augusts
Registered User Joined: 07 January 2017 Status: Offline Points: 180 |
Hi!
I started my way by using the available plans for Cubo Sub. I was very impressed with the results, with a similar driver as yours also 9mm Xmax. You can find the Cubo Sub hornresp input screen copies online, input those into hornresp and then learn from a readybuilt and tested design. There are many factors you have to take into consideration when starting with hornresp and simulating speakers.
no. Fs of that driver is far too low
Augusts
We have been using 18sound 18lw1400 in a cubo sub for years now, it is awesome and its fs ir 31Hz
Here is a graph I did with cubo sub and the RCF , the peaks are only 0,5db higher than the sim with 18sound. Maybe there are other factors? looks the same as 18sound
