  New Posts New Posts RSS Feed - 18sound 18LW2420
18sound 18LW2420
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Topic: 18sound 18LW2420
    Posted: 22 July 2021 at 10:25am
Wondering which cab designs people have tried these in with success.
Anyone tried them in Gsub from this site?
Tried them in some Martin 2x18 reflex copies, results were very mediocre.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2021 at 12:41am
If you are aiming to attain 35 Hz - 30 Hz, the parameters show this speaker will have difficulty achieving those frequencies with great efficiency. You can always tune the Martin Box higher and achieve 40 Hz - 50 Hz.
Best Regards,
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2021 at 9:40am
Best Regards,
Thanks for input Elliot.
Myself and FOH engineer have already decided the Martin copies are definitely too small for these drivers, and they probably need at least 220L chamber.
Not really looking to fund custom builds, so currently looking for used, cabinets.
Fane Constructor and BCsub 18 design, are two of my favorites.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2021 at 12:13pm
Either design should allow you to reach 40 Hz using that driver.
Best Regards,
Daddy Culture View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daddy Culture Quote  Post ReplyReply Direct Link To This Post Posted: 24 August 2021 at 9:30pm
Someone have ever tried this (18LW2420) on SUPER SCOOPS?
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 25 August 2021 at 2:01am
T/S parameters suggest not very Scoop compatible.
But may do well in Folded horns
Edited by levyte357- - 25 August 2021 at 2:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daddy Culture Quote  Post ReplyReply Direct Link To This Post Posted: 25 August 2021 at 2:20am
Hey levyte, thanks for reply...
As far as I know scoop compatible drivers must have: FS -35 / QES -35 / QTS -35 / VAS -360 / BL +24 / XMAX +7
18LW2420:
Fs 33 Hz
Qes 0.33
Qts 0.31
Vas 255 lt.
BL 24.6 Tm
Xmax 10 mm
It passed all the requirements.. it is very similar with TBX100 thats a tested and prove driver...what makes you think its not appropriate for scoop?
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 25 August 2021 at 7:54am
18LW2420:
Fs 33 Hz
Qes 0.33
Qts 0.31
Vas 255 lt.
BL 24.6 Tm
Xmax 10 mm
B&C 18TBX100 maybe impressive to some in a Scoop, to the more demanding Scoop owners, it is classed as average.
I know what T/S Scoop Compatible drivers typically have, I was the one who requested the creation of the Scoop forum over 15x years ago, and also originally posted, the typical T/S parms, for Scoop compatible drivers.Wink
There is a difference between a driver that is optimal for Scoops, and what will work, somewhat.
Manufacturers, have locked onto this, and now actual state, certain drivers are great in Scoops.
If you had read the Scoop forum, you would have seen detailed discussions, of what many class as characteristics of optimal Scoop drivers, as opposed to cheaper drivers, that might work.
Finally, this is not the Scoop Forum, suggest you request admin, to move this thread, there.
Edited by levyte357- - 25 August 2021 at 7:59am
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2021 at 6:39pm
i have a friend with 18TLW3000's in sealed boxes. he has 8. they sound amazing
