WINisd saving driver parameters |
zigzagwanderer
Registered User Joined: 01 February 2021 Location: sw uk Status: Offline Points: 48 |
Posted: 13 October 2021 at 1:32pm |
Hi
I've been learning to use WINisd for the last couple of months , version 0.7.0.950 and I don't seem to be able to save edits to driver parameters. I don't get an error message or anything and it looks like it has saved but the next time I use WINisd the parameters have reverted to the pre edit figures. Am I likely to be doing somthing wrong or is this a software bug ? |
studio45
Do you mean when you edit the parameters from your project window? Those changes aren't saved to the database, it's not a bug it's just the way it works.
If you want to save new or different parameters for a driver, you have to choose "new driver" and make a new entry into the database. If your driver is already in the database, just give it a name like "xxxx V2" so you know which model is which. However, you may run into problems if WinISD's parameter checking routine doesn't think your driver is real ;)
zigzagwanderer
Ok that makes sense, thank you Yes I was trying to do it from the project window |
DMorison
Rather than create a whole new driver record, you can edit the database driver records by using the "Driver Database" button and then loading the model you want to edit.
As Studio45 says, you do have to do it this way rather than in a project, as those changes would only be saved within that specific project.
zigzagwanderer
Ahh yes of course Seems obvious now thanks
