  New Posts New Posts RSS Feed - Tony Wilkes Q12x2 Sub + 2x8 Top
LeNNNseN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeNNNseN Quote  Post ReplyReply Direct Link To This Post Topic: Tony Wilkes Q12x2 Sub + 2x8 Top
    Posted: 13 October 2021 at 5:18pm
Hello everybody,
i am new in this forum and i have a question. I heared that a guy called tony builds a double 12 inch subwoofer with double 8 inch tops in the past. He sent his plans to everybody who asked for it. Is here anybody who has his plans and would share it? I know that he dies for a few years - very sadCry. God bless him.
i asked this question, because i have two bms 12n630 woofers and i want to build a sub like he did. Sorry for my bad english - i am from germany.
Greez Star
LeNNi
DMorison View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2021 at 9:11pm
Forum member "Bee" was the keeper of Tony's plans as far as I recall, once you have been around long enough to accumulate at least 10 points you'll be able to PM him and ask.
Or you might be able to contact him through his business, Elements Audio.
PS, no worries about your English, it's still about 3x better than most British people's attempts at speaking foreign languages!
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 14 October 2021 at 7:23am
Ben (bee on here) at elements audio is a very busy guy but keep trying he'll give you what your after.
Normally just asks for a donation to the british heart foundation in tony wilkes memory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeNNNseN Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2021 at 8:53pm
Okay guys, it's not possible to register on his page -.- wtf. i cannot write a pn in this fourm cause i dont have enough points... this makes me sad. Can someone help me? Can someone write him an pn?
... greez
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2021 at 10:03pm
Try elements audio on Facebook.
markie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2021 at 11:29am
I have a copy of the original Q12 that came from Tony himself back in 2015. I believe the 2x12 box was simply  double width.
You only have to post 7 more times and you can use the PM system. Reply to this, then post a "Hi I'm LeNNsen from Germany plus 5 more and you can PM me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeNNNseN Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2021 at 8:08pm
@markie , thank you dude! if i could, i would spend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeNNNseN Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2021 at 8:09pm
i need to post im sry guys....
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeNNNseN Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2021 at 8:45pm
i need to post im sry guys....2
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeNNNseN Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2021 at 11:30pm
i need to post im sry guys....3
Post Options Post Options   Thanks (1) Thanks(1)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2021 at 11:37pm
Here's some info from Tony back in 2015:-
"This design is a compromise between extension and size, its -3db is 43hz and it is -10db at about 35hz. it has no problem with Xmax
limitations 40hz up at full power.
To get the correct tuning for the box it needs to be lined with 50mm egg box foam or similar, also make sure you sit the driver down on a foam gasket, I use some stuff from a guy on Ebay,
    Tony"
Edited by markie - 26 November 2021 at 11:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2021 at 12:04am
So does that sound like a cab that will fill your needs???????
