  New Posts New Posts RSS Feed - Closed-Box Loudspeaker with a Series Capacitor
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Topic: Closed-Box Loudspeaker with a Series Capacitor
    Posted: 22 January 2022 at 1:02am
thiele's paper
I have successfully followed the procedure to calculate the box parameters from the driver parameters for the four example transfer functions in table 1 - except that the second line for 0.5dB Chebyshev doesn't match what I get. Either the calculated values in the table are wrong, or the values of x3,x2,x1 in equation 25 are wrong. I can't quite follow how x3,x2,x1 are derived from the specified value of K so can't check. Anyone understand the bit about normalisation on p.579?
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2022 at 2:48pm
tried taking coefficients from these tables and rescaling so that x0 term is 1. but that's not the answer Confused
bbm:978-0-306-47953-3/1.pdf (springer.com)
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2022 at 5:54pm
It seems like the normalisation is just the process of identifying the maximum and minimum value for the excursion from the calculations, and using these to determine the normalised value for any value within the data series?
That's usually done by:
x_(norm) = (x – x_(min)) / (x_(max) – x_(min))
Where x in this case would be the calculated excursion at a given frequency. That normalises values as 0 to 1, if you want it to go from -1 to 1 then just multiply the 0 to 1 values by 2 and subtract 1:
x_(norm) = (2*(x – x_(min)) / (x_(max) – x_(min)))-1
If you’re feeling lazy, Matlab (and therefore I presume Octave) has a dedicated function, unsurprisingly named normalize.
https://uk.mathworks.com/help/matlab/ref/double.normalize.html
As for the Chebychev seeming to be wrong, have you checked for any "comments on" follow ups to the paper? One thing the AES doesn't seem well set up for is updating papers with corrections.
Edited by toastyghost - 22 January 2022 at 6:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2022 at 11:31pm
a value of K is chosen to give the desired ripple. maximum value is 1 and minimum is
1/[1+K^3/(4+3K)^2]
ripple in dB = 10.log(min)
I guess you put that value of K into eq22 but how do you get from there to the coefficients in eq25 and eq26?
can't find any comments on the paper - and remarkably little discussion of the technique anywhere.
stevie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevie Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2022 at 4:03pm
You might be overthinking this. The technique works on speaker systems that are underdamped, i.e, peaking around 100Hz or so. The series capacitor flattens the peak and extends the LF response somewhat. It works on reflex boxes too. Capacitor values tend be be somewhere between 400 and 800uf.
With reflex boxes, it increases power handling at low frequencies, although I've never been able to figure out how much power the capacitors can handle. With values that high, electrolytic are the only choice.
I've never bothered to calculate the capacitor values. It's easier to try a few values and measure what they do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2022 at 5:52pm
yes, if you are decided on a driver then there are only two variables - Vb and capacitor size - so it doesn't take long to find a combination that gives the desired response. I've been modelling in Hornresp but ended up with a much smaller box than suggested using the maths in this paper.
Using trial and error for a vented system with capacitor means at least three variables - the chance of finding the best combination without working to a mathematical alignment are slim and time-consuming.
turbo7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote turbo7 Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2022 at 1:59pm
This looks interesting but i cant have a look a the paper, paywall..
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2022 at 3:13pm
if anyone wants a copy of the paper then send me a PM with your email address
